900 X Overunity
Started by FatBird, March 27, 2015, 09:50:11 AM
MarkE
Quote from: ramset on March 30, 2015, 09:43:25 PM
Mark E
Soo if you believe this can be properly vetted in a black box with no other info ...
please explain what that would look like ?
There are several "this".
1) Claim of gram for gram evolution of hydrogen from water.  Based on weight and volume of apparatus determine greatest mass of hydrogen that can be stored within the apparatus by any conventionally known means.  Weigh apparatus at test start and end.  Externally supply water source greater than or equal to ten times the determined mass.  Externally draw off emissions measuring mass flow rate and analyzing gas content.  Run until the earlier event:  water source is exhausted, or unit stops emitting hydrogen gas. If the water source exhausts and the hydrogen mass output matches to 90% or more, and the ending weight is no more than the sum of the starting weight plus the water added less the gas evolved the claim is met.  Otherwise the claim fails.
2) Claim of oxygen fission.  Determine by volume and mass of apparatus under test the greatest mass of elements H through N that can be stored within the DUT by conventional means.  Weigh the DUT before and after testing.  Supply pure O2 supply to apparatus.  Under conditions as in 1) operate the unit until the earlier that it has been supplied 10 times as much oxygen mass as mass of emitted gasses of any composition of elements from H to N.  If the emitted mass of gasses from H to N equals or exceeds 90% of the oxygen mass supplied to the unit, and the unit weight after testing is no more thn the sum of the starting weight plus added oxygen less the weight of the gas evolved the claim is met.  Otherwise the claim fails.
Shall we go on?
ramset
Sounds like a proper Path, It would be very good to ask at SRI if similar protocols were
requested.
some will have a specific format they follow,disclosure or "tell your story walking, there's the door, others, will bend over backwards to do as you propose ,much bigger commitment and cost .
I will call them in the next few days.
Thanks Grandma
MarkE
In more than one year they have never published such test results.  To quote TK:  "I know why and so do you."
