Thanks to ALL for your help!!
Thermionic Overunity Generator my gift to the world.
Started by Arthur1, March 31, 2015, 02:03:48 AM
profitis
Here's a better one:
Quote from: TinselKoala on Today at 09:17:26 PM
---Silly boy, you know electrons don't exist, SON.'
Is this a claim or argument? Please give your assumption-status QED :) (sarkeizen special)
joel321
QuoteI think Joel is damaged from excessive use of drugs....possibly vaccine abuse.
This was posted on April fools day. And since I don't believe that anything home made can "damage the grid" is really plausible....then I can conclude that: The poster is joking. That or trying to fool the forum lol.
Now that does don't mean that the poster (OP) did not pick a bad timing. But it is what it is.
sparks
    If this theory pans out it means tv crts are running at overunity.  Hmmmm.  Could be.  You add up the heat the light (including hf light in the xray bands etc.   I did get some weirdnesst happening when I powered up an iron coil with an old tv chassis.   Two plasma brushes from the ends of the coil, an ion wind you could have sailed a toy boat with,  blue white light from the "brushes" and a few dbs of audible noise resembling drawing air through your teeth from the coil ends.   The  ion wind felt cold.  Started about 2' out from the coil ends which were facing down.
No typical purple corona discharge crispy blue white full spectrum look.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
ATOM1
Respect this man !!!
This works ! And please stop using old school theory to map out a free energy current all the books don't account for a free energy state to every exist. All the universities in the world can get there head round it and ohms law will never permit it ... So get rid of ohms law in a free energy equation and throw away the stupid physics book just hold the dictionary of electrons in one hand and in the other all the missing free energy formulas that will one day be added...
Idiot school kids insulting work they have not built or tried let alone ever built a free energy system and there understanding of the electron is incompetent and incomplete ..
Electrons has strangeness to them they can and will do many things that don't fit normal physics but with this device its easy to spot the free electrons from aluminium and they alone can give an OU response Also the atomic boundaries that free electrons make up in aluminium, silver and quite a lot of other atoms are all electron donors... An electron avalanche effect is all you need and in this device I see it clearly possible taking into account the difference in atmospheric pressure inside and out side around the load with a directional path towards earth via the load ect .....
All free electrons from such atoms when liberated will excel orate towards earth and to some people its all at the speed of light that in fact is no true there is what we call quantum delay between voltage and current with current lagging behind the voltage .. Its not possible to measure the correct speed of current with an OS the screen only shows you the crest of the energy wave not the correct position of all the electrons in the stream of energy...
Electrons do not orbit there nuclei they quantum jump around it and to be honest one can also conclude that electrons can also do the same thing along a flowing currant. It is obvious with these simple facts that electron pressure can be self induced by such a effect. All those stupid out of date maths are just words and numbers they never fully confirm the finite quantum values that electrons demonstrate...
I have one special free energy 500w motor that runs at 4000 rpm at 00.01v at 00.01 amps completely destroying all know laws of physics.... This is only one of many free energy technologies I have ....
Another point is the load may also attract heavy alpha particles or even permit them to influence the electron exchange by means of particle field coherence ...... There are many other possibilities that can be stimulated to increase the end result but for now take this as a lessen in particle field observation than begin to look again at the electron and what it truly is !
Also the correct definitive construct of an electron is 2.2 trillion x and y particles that makes up one electron and is why an electron can be split in two.... You may also consider this as the reason you get a north and south pole in EMF but you can also achieve a mono pole electron field that it self would equate for 100% increase in power....
Allow me to fill your mind with what you don't know it will save you forty years of work and to that the most amazing thing about an electron is that can also be in two or more points of space and time at the same time you may consider this and observe that the electron could exist as only one electron divided into infinity..  This would indicate all mass in this dimension is sharing the same electron and that to me makes a lot of sense as from a so called nothing all that is was created. Nothing divided into infinity = one electron ! All the other particles represent an evolution of the first particle which is an electron.. Entropy and enthalpy are points of charge and discharge you can have one without the other and would be fair to say that all other energy that is an extension to that of the first electron are just small pockets of such energy enclosed like an moment of nothing in an envelope of time and space...
Just one proton has 1kw of energy trapped inside so please don't look at mass as if its empty its full to the point where no more energy can be kept inside. Let us also presume that one proton was to leak out some electrons and add them to the currant and that it self is more than possible.The life span of a proton is 36 billion years , THE UNIVERSE IS 13.8 BILLION years if protons did not leak out energy and lets say for now its impossible to determine what ones do than at the very second of the last second in the 36 billion year time scale all protons would just vanish.. I doubt  that to be the case and the point here is if one mans technology was to show that its over producing energy and another man builds the same technology without the same result than the mass of the technology that is over producing energy has some very important protons in it hahahahah do you now see my point ???????????????????????????
So to the man in question please keep very safe your technology with this in mind and stay in touch !! I personally have been in search of such protons for the past 30 years . And to all the young up starts this universe is a supernatural one expect the unexpected and never trust an electric meter or a O S for measuring the quantum effects of an electron...
Any more idiots who spout out insults to anyone that present information in an up front and honest way should truly think there reasoning through and stay detached from personal remarks. Science has no place for egos and remember anything is possible even if at first it seems impossible.
ATOM1
