Thanks to ALL for your help!!
Thermionic Overunity Generator my gift to the world.
Started by Arthur1, March 31, 2015, 02:03:48 AM
profitis
Atom'the
most amazing thing about an electron is that can also
be in two or more points of space and time at the
same time you may consider this and observe that
the electron could exist as only one electron divided
into infinity..'
Heisenberg baby,heisenberg..mwa
Void
I am reposting my test results for Arthur's setup here, since this is the original thread.
I tested with this using an Eimac 4-400A tube, using a setup
exactly as it was described by Arthur. I tried applying the 2000VDC to the
control grid and then the screen grid since Arthur didn't specify, but all
I was got was an internal arcing noise in the tube with either grid, and although the internal
arcing noise eventually stopped after several tests, the voltage on either grid would
still not go above about 400VDC. Not sure if that was due to continued internal arcing or
some other form of leakage or what.  I had about 6,600 ohms of resistance connected to
the plate for the initial testing, and only tried removing the resistive load to compare when
my tests were not working (only a small voltage seen on the plate), so all my initial testing
was done with the 6,600 ohms (using appropriate power resistors in series) connected to the plate.
I could get between 4mA to 5mA grid current with the applied grid voltage set high
enough, but the voltage on the grid still would not go above 400V (measured
on my scope) and there was only a tiny output voltage on the plate with or without the
resistive load connected. The internal arcing may have damaged my tube, not sure, and those 4-400A
power tubes are not cheap. Since the tubes are so expensive ($120 USD or higher) I won't
buy a new 4-400A tube to try further. :) Maybe it really was just a hoax, but Arthur seemed to
know what he was talking about, so that is why I tried it. My circuit test setup was identical to the
schematic Arthur had provided. Too bad Arthur didn't stick around as I would be interested to
hear what he has to say about my failed tests. :)
All the best...
isawit
before we truly understood atoms structure, all theories are uncertain.
anyone knows how 1 electron and 1 proton able to become a stable hydrogen atom?
if so, please share the secret!
