Gadolinium Magnet Generator.
Started by synchro1, April 03, 2015, 02:02:04 AM
synchro1
Imagine placing a hot cup of water over a permanent Neo magnet disc with a gadolinium piston underneath suspended over an ice cube. The oscillation should be perpetual and frequent, as the heat from the cup of water reinforces the magneto heating from the PM, and the cooling from the base module causes the gadolinium to transition back to it's magnetic state after it drops to the cooling base.
synchro1
This inventor calls the overhead permanent magnet the "Hot Reservoir" A steam iron and a laser thermometer could easily help trigger an oscillation in the gadolinium cube between the magnet and the "Cold Reservoir" underneath!
synchro1
One 12 volt Peltier Module attached to a heat sink can cool the base and heat the overhead magnet through convection from the heat sink cooling fan. The colder the base the warmer the air circulating over the roof magnet. This combination would work anywhere regardless of environmental temperature. The Arduino can hit the junk drawer too
synchro1
A "Hallbach" array would work best as a "Hot Reservoir" roof magnet primarily because it doubles the field strength while halving the heating mass. A disc of wedges in a ring holder can focus the doubled attraction strength in a downward direction. A CPU heat sink would position over the "Hallbach Array" and circulate ducted hot exhaust from the Peltier module underneath to heat the magnets over 68 degrees Fahrenheit.
synchro1
I imagined molding a gadolinium pot and screwing the coil inside. Secondly; The pot can nest in a cold fluid receptacle at the base and recess into the hot reservoir magnet roof. Thirdly; internal contacts can send output through a square axle with spring on top.
The gadolinium pot will not interfere with the faraday effect, while non magnetic, as the pot oscillates it's coil wraps inside the powerful Hallbach flux field.
