Gadolinium Magnet Generator.
Started by synchro1, April 03, 2015, 02:02:04 AM
synchro1
I'm making major new "Quantum Leap" discoveries. The gadolinium cube generates voltage in the electro magnet with the Neo tube attached, and no attraction between the gadolinium and the electro-magnet. This is an awesome effect. This eliminates magnetic drag from magnet rotors. The power is about the same as when attached to the laminated stator, but both the magnet and the gadolinium just slip right by, but the power appears anyway!
Think about it; A gadolinium shield covering the surface of a rotor magnet would eliminate any attraction but still generate power in a ferrite core output coil with no cogging.
Zero Lenz drag! A result of "Magnetic Field refraction". A gadolinium sleeve and "Skycollection" style rotor This kind of output rotor would spin for free, two block magnets nested inside would work fine. This kind of output rotor would generate free power with it's hyper dimensiaol field. __________________
synchro1
Here's an interesting design. Can any features of gadolinium improve it?
https://www.youtube.com/watch?v=tfs6fwNA9r0
partzman
Quote from: synchro1 on September 26, 2018, 02:10:25 PM
Synchro,
This is all really very interesting but would elaborate a little more on your statement above?  What is the "neo tube"?
Also, what was your source for the gadolinium cube you are using?
Regards,
Pm
FixedSys
Quote from: synchro1 on September 27, 2018, 06:55:26 AM
Same basic design but use a Gd shield where there is no steel shield and remove the steel shield.
