Magnetic engine 2.0 uhhhh
Started by superhero, April 12, 2015, 06:04:28 PM
sm0ky2
Quote from: superhero on April 12, 2015, 06:04:28 PM
iS this possible? F output > F input?
F output = force generated due to the displacement of piston magnet
F input = force required to move the shield away from the piston magnet.
creating a difference in Force is simple. But force alone, does not mean an imbalance in Total energy.
You need Force over distance.
and when you add up all the forces, over all the distances, you can get a clearer picture of whats going on.
Quote from: lumen
I wonder if the "Pin to Pout" chart is from actual measurements.
Appears simple enough to build for a test, but every system I tested that used shielding always consumed any gain operating the shield.
This is true in most orientations. But not always.
There are vectors at which motion through, into, or out of the field is not resisted by the magnetic force.
Try: perpendicular, at a set distance from the field
as  Benchmark to start learning from.
lumen
I am convinced that it's impossible to get an energy gain from magnetic fields whether electrically generated or permanent magnet.
Not to say that it is forever impossible because some new material may be developed with properties that might provide some OU effect.
