Rosch taking orders on OU Bouyancy device.
Started by ramset, April 26, 2015, 09:52:03 AM
Quote from: sterlinga on April 30, 2015, 02:02:04 PM
At 17:36 GMT, Roberto wrote: "Sterling, hi, this is the Second Webcam, we can access locally only to show a video of the generator & compressor. This Cam also has IR LEDs."
That makes sense. The livestream camera was on infrared, so any light would be amplified, so a little light from this second camera, poised above the AuKW would be exaggerated. Consistent with LED as described.
This is at least plausible. Thanks for running this down.
MarkE
Quote from: ramset on April 30, 2015, 01:58:21 PM
TinMan
Don't you know that 200 years is a long time...?
it really really means something...
>>>>REALLY<<<<<.
maybe Roger Shawyer didn't listen either..
and now he's gonna rewrite the Book .
He has been trying for over a decade and his math is still crap.
here
http://www.overunity.com/15741/april-29-2015-nasa-conforms-roger-shawyers-space-drive-works/msg448608/#new
Except that they didn't.  In order to actually test that the device generates its own tiny accelerating force, all other forces have to be reduced to a much lower level so that they do not blind what the device does or does not do.  That requires testing in a very low pressure environment so that charged gas molecules don't push the thing around.  They were not equipped to do that and did not test in a vacuum.  So basically, it was a waste of time and resources. They set up plans to test in a vacuum.  I don't know when those tests will be complete. But never let facts get in your way.  When the Kool-Aid's running, something has to give.
Oh yes I forgot Mark E says Roger Shawyer and NASA are full of Garbage too..
yeah, its pot luck all the Garbage they fire into space across squillions of miles
and land on a Fleas Buttocks .
all Garbage pot luck ..
their Clueless ...
Just ask Mark E he'll tell you all about it.
probably right now......
Hey what's a little misquoting, and mischaracterization huh Chet? Because if you had an actual argument you wouldn't have to resort to such techniques.
MarkE
Quote from: TinselKoala on April 30, 2015, 02:28:37 PM
http://www.flywestwind.com/hangar/aircraft_files/foms/B763ERFOM.pdf
So flaps need to be fully retracted at 260mph.  The plane obviously is not coming apart with the flaps retracted at 220mph.
MarkE
Quote from: TinselKoala on April 30, 2015, 02:35:21 PM
There is definitely a light source up there.  The picture isn't clear enough for me to see if that is a camera head or not.
