The torsion generator of energy
Started by MackorLab, April 29, 2015, 11:37:58 AM
MackorLab
The colleague, here with such disk anybody has no desire to be played? If to enclose it in two put aluminum plates with cut under this disk and then to untwist counterclockwise, the engine from HDD. Then towards the rarefied plate the longitudinal wave of Nikolaev which transferring electrons will extend, will constantly try to attract on a longitudinal trajectory petals to a plate.
P.S. From where energy will undertake.
As Akimov spoke, environment pulsations constantly generate an electron and a positron which for a moment appear, fixed by devices and as not from where appeared, also in there is no place disappear (are annihilated).
On the assumption of developers of a disk, the high-speed air whirlwind, will create the torsion field which will take the taken-off electron and will tire out it in a path on a disk, thus it it everything will move away further from a positron that will prevent its premature annihilation of bases of commission of work, and here when it approaches edge, there already forces of Nikolaev will enter work and will force an electron to share energy, part on promotion of a disk, part on plate charging.
Low-Q
MackorLab
Sorry, this opinion is the of official Russian science.
Clearly that it will reject similar things.
We suggest to make such disk and to test.
And you now tell that I am a swindler, but it not so.
It is better to make a similar disk on qualitative plant as in house conditions we can lose centering accuracy. The minimum order 5pcs is necessary for the order at plant. If we still add to each disk PCB of control of the HDD drive. That on five sets the price will be $100, no more. These are $20 for a disk and PCB of management. It is necessary for us four more colleague for check this version the fuel-free generator. We will give the list an electronic component and the scheme. Aluminum dish(2pcs) you to buy or do.
MackorLab
Look at Shauberger's engine with top and you will see similarity of system.
vasik041
QuoteWe will give the list an electronic component and the scheme.
Can you post it here ?
It would be interesting to know more details and see photos of working device.
