How Rosch probably faked their 5 KWatt KPP AuKW
Started by hartiberlin, May 05, 2015, 10:41:49 PM
Berto3
@memoryman
Why are you here on this forum? Only to find arguments why PM and OU can't exist? What or who has convinced you that the KPP is a fake? Do you have the courage to go to Rosch to investigate the system?
I would like having a space and people around me with the right intention to build an OU system. The only reason for me being on this forum is to find some arguments why this system can work. But I suppose this is not the right time. First some people here have to crack the nut of there own prejustice about the KPP system. Be carefull, there is no difference between believe in PM/OU or believe in scientific or mediated dogma. It has more to do with an open or closed mind. 100 years ago, people thought a plane could not fly because it was heavier than air...
memoryman
The plane argument is old and tired. Even Stefan Hartmann knows why is cannot work. Go to http://revolution-green.com/rosch-smoking-guns-and-the-scientific-explanation/ on some insight.
No, I don't have to inspect it personally to know it's a fake because I am that good.
Berto3
Ok. The answer you give is exactly I mentioned as a closed mind. Cynism is a stong quality. Sorry I cannot handle that. End of discussion.
memoryman
A closed mind is one that cannot consider alternative possibilities; if I had the desire, I could show you that I am the opposite of that, but seeing that your mind is made up about me, I'll pass.
Enjoy your closed mind (you have lots of company).
MarkE
Quote from: hartiberlin on June 21, 2015, 10:08:05 AM
Here is the TÜV Report from the small model:
http://pesn.com/2015/06/20/9602633_Why-Im-100-percent-sure_Roschs-KPP-Free-Energy-Technology_Works/TUV-w-recactions.pdf
That is not a TUV report.  It is a report from a company called WTLab.  The report is a bit of a joke.  The claim is that the column of water and the passive bits within it generate energy.  The shaft mechanical output was never measured.  They did some odd things measureing only the generator outptu or the battery outputs but never both at the same time, and then they calculated efficiency in one case as:
Page 8 efficiency = (resistor load power - battery power) / (resistor load power + compressor power - battery power)
and in the other as:
Page 9 efficiency = (dc generator power  - compressor power)/(dc generator power)
Neither equation makes any sense in terms of evaluating the system.  There are other curiosities in the report including that the battery bank voltages were reported to be exactly the same: 29.45V.
