R-Walker Selfsustaining Free Energy bike from Mexico
Started by hartiberlin, May 11, 2015, 02:29:11 PM
lespaul109
I'm going to start working on a replication. It seems to me that it is related to Don Smith's references to super capacitors. Watch the #6 video of his 2005 lecture. Two super caps can shuttle energy through a motor recharging each other. A super capacitor in series "looks" like a wire to the flow of current until it charges to a certain amount. The current that would have been wasted flowing into the positive side of a battery or super cap, without the cap in series with the load, is collected for free. You would have to use a boost converter so the charges wouldn't balance out. I have some 150W models that turn on at 10v. One thing about these boosters is that the output is stabilized so if the cap that is feeding it is draining from 16v to 10v, the output stays at a constant voltage.  Once the collection capacitor is charged to 16 volts or so, the circuit changes so that the collecting super cap in now feeding the load and the other super cap is now acting as the collector in series with the load. I don't know if I'm smart enough to design the switching circuit though. Maybe someone would help me with that part. It would need to be voltage controlled somehow. Arduino may have a use here. There may need to be a small generator connected to the drive system of the scooter to make up for what is not recovered in the storage caps. I apologize for any obvious or rhetorical statements that I may have made.
memoryman
lespaul109
I also have a 10 farad car audio cap(PCX10F) in the shape of a car amp that I disassembled to check out and test the two large caps inside. When I opened her up, the first things I saw were six 10F 2.7v caps wired in series. Those were in parallel with two 2inch dia. 8in long aluminum cans that I wanted to test. After disconnecting them from the bus bars I tested each by charging to 14 volts then discharging through a 47ohm resistor. After doing some math, they came out to around 0.2F or 200mf each. Lesson learned. Here's a video about building large value super caps for really cheap. I found 10F 2.7v caps for $1.50ea if anyone wants to build there own super cap bank.
https://www.youtube.com/watch?v=gTt_YBzJ_Dk
lespaul109
