R-Walker Selfsustaining Free Energy bike from Mexico
Started by hartiberlin, May 11, 2015, 02:29:11 PM
Magluvin
Quote from: Groundloop on May 25, 2015, 02:07:23 PM
Hi Bill,
The drawing in the patent can not work as I see it. The rectifiers is not connected correct.
I did try to make a cleaned up drawing of the left bottom part of the circuit diagram.
GL.
It looks like, if any of the circuits are correct, that the seemingly wrong way diodes can act as a spark gap using reverse breakdown voltage. If the cap is charged, then also the capacitance in the transformer is charged. Capacitance btween primary and secondary. If that charge exceeds the breakdown voltage of either diode then something happens, whether it is current through coil 59 and 58 is induced, or possibly something else.
Would probably be good to just try the simple config below with some tests before we say the diodes are in the wrong configuration. ;)
Mags
Groundloop
Quote from: Magluvin on May 25, 2015, 06:21:36 PM
Mags
Hi Mags,
Do you know the reverse breakdown voltage of mercury vapor rectifiers?
GL.
Magluvin
Quote from: Groundloop on May 25, 2015, 06:47:14 PM
Hi Mags,
GL.
Hey GL
No I do not.  I guess it would depend on the device.  Have read something that they are noisy.
Mags
jimbo
Hi guys im a little confused .in his patent gb191505591. He is using two sets of caps on series
And charging with a single primary cap thu an isolation transformer with each end of the secondary going to a cap string in series and earth grounded this should give less charge .but he walks thu it explaning how it doubles out put? Hes an electrical enginer. Im missing some thing does any one see it? Thanks jim g
jimbo
Whats happen to the r-walker page? And the subject is missing from the index ? How do you
Contact the site controlers ?
