Permanent magnet motor
Started by Jim36, May 18, 2015, 01:24:19 PM
ayeaye
Guest1289, talk about the coils there http://overunity.com/14925/negative-discharge-effect/#.VdFQ5tcuviY , not a right place here. In brief, the voltage induced, depends on the speed of switching the current, not on the strength of the initial current, e = df / dt, or such, this is what it is about, very basic, and this is what induction is. Now the induced current should remove the magnetic field, and it will, but these processes have a certain inertia. And this is why there is a voltage spike.
guest1289
Random thought,  wonder  if   'quantum entanglement'  could somehow be the ultimate secret behind  gravity ( and magnetic and electric fields ),  if so,  could it be that by modifying one of two entangled  things,  be the  utimate secret to either turning  off or creating  the above forces
ayeaye
Quote from: guest1289 on August 17, 2015, 01:56:11 PM
Gravity by the standard model, is particles sucking a kind of space grid, made of Higgs bosons. The Higgs bosons then fly somewhere else, where they form more space grid. The space grid is most likely dynamic, it is that "quantum foam" which fills the vacuum. A huge movement which is the source of the zero point energy, which may be the unknown energy causing the overunity.
But i think quantum entanglement is certainly the ultimate secret. I think the reality is a network, a pure entanglement, having no dimensions. Like the David Bohm's implicate order. The space is formed by a dynamic grid made of that network. Movement in space is just changing connections to the different points on the grid. Moving is thus also change, and change is general. If we understand that network then sure we can do everything, imaginable and unimaginable. But you are thinking about things which you are not supposed to think, this may make you to understand, but you are expected to be limited. Interestingly though, no one agrees to be limited.
ayeaye
I don't know what to say. Try to strongly circularly magnetize a thin ring magnet. Then maybe some field is near the surface. Maybe one may try with coils first, like a piece of iron pipe as a core. The magnetic field in the toroid core should be exactly the same as the circular field in a permanent magnet. See whether it anyhow interacts with a pole of a permanent magnet, in place where the core is exposed, and where are no windings.
guest1289
It  seems  I may have just invented a new type  of  brushless( and more efficient ) type of  DC motor,   the statements posted on  http://overunity.com/15978/new-reactionless-motor-from-india/msg459441/#msg459441  ,   prompted me to invent it .
I first posted this invention,  in the above  thread.
My  initial design  is simply a wire carrying Dc current,  causing a  Donut-Shaped  magnet,  to spin on an axle  (  this  Donut could have a normal magnetic-field,  not one running around the circle,  so it's easy to make  ) .
(  Of course that  wire should probably be replaced with either a coil ,  or something similar to multiply the power  )
(  On the above  thread,  I also posted my reasons/theories  why  a  Donut-Shaped-Magnet  with the  magnetic-field  running around  the  circle of the Donut  needs to be created,   it's to prove or  disprove  theories.   But my new  brushless-DC-motor will not need an un-makeable Donut-Shaped-Magnet   )
