Permanent magnet motor
Started by Jim36, May 18, 2015, 01:24:19 PM
stoyan_
I guess its all about someone to build it and test it.
circular magnetic field between north and south pole.
cheers
guest1289
The webpage you posted, showing the theory,  does make some logical sense.
That webpage shows the surface of a superconductor under an electron-microscope, showing some evidence of the theory.
The theory says that the lines of the magnetic-field  are like tubes,  vortex-tubes, I think.
(  But  superconductors have very different characteristics to normal permanent-magnets  )
IF THE THEORY IS CORRECT,  then it would provide the necessary traction, or gear-wheels,  to build a  magnet-motor,  and it would be the simplest design.
This was tried in this thread,  and very amateur prototypes were built,  they posted some photos,  from the post below :
http://overunity.com/15774/permanent-magnet-motor/msg460716/#msg460716
to the following post :
http://overunity.com/15774/permanent-magnet-motor/msg461529/#msg461529
  But I don't think it was tried very professionally, AND THEY DID NOT KNOW ABOUT THE THEORY YOU HAVE POSTED,  the attempts at simple prototypes were of very very poor quality,  but they did try though.
   (  I also wonder what you can see,  in the  magnetic-field-viewers  that people buy,  but I assume what they see is the variation in the intensities of the fields,  because the resolution of those  magnetic-field-viewers  would be very very low,  that is obviously big understatement  )
   I have some magnets shaped like watch-batteries( or buttons ), but slightly larger than watch-batteries.
   I just built the only prototype I could,   VERSION-1, in the 2 diagrams below.
     I could only build it very amateurishly,  it did rotate, when I moved it toward the stators,  but it is very in-accurately built, not sufficiently symmetrical.
     I think the main reason I got some rotation is because I moved it towards the stators while at the same time the axle was not perfectly in the middle of the  magnetic-wheel-magnet( magnet shaped like watch-batteries or buttons ).
    So I don't really know about the results I got from building VERSION-1.
    (  And the magnet needed to build  VERSION-2, in the diagrams below,  is not sold anywhere )
    Yes,  these two versions would have to be built,  and tested, very professionally .
stoyan_
lets stick to the picture attached from me initially with the shielded rotor magnet between N and S.
stoyan_
There is also another version. Perhaps easier to build.
Sorry for ugly drawing :)
stoyan_
