Permanent magnet motor
Started by Jim36, May 18, 2015, 01:24:19 PM
stoyan_
Another easier version
The shielded magnet is the stator, the disk is rotating.
guest1289
stoyan_
    When you clarified the idea you are posting,   I realized that I included the same idea you are posting,  this  magnet-motor,   in something I filed at the patent-registry in the  middle of  2015 .
   (  Obviously it's not patented,  and  patent-registries  these days do not permit overunity devices.  But,  I think the way to try and get around that rule,  is to file them as toys  )
   My  magnet-motor  uses  2-ring-magnets on top of each other,  but with space in between,  and in between is  a rotating component which is shaped  like an aircraft-wing( or a triangle ) in order to gain lift in that particular magnetic-field,  which should result in propulsion.
   However, the shape of your moving-magnet  is a symmetrical-square/rectangle,  which is different to mine.
   The diagrams of that  magnet-motor  design are below .
   (  that document was all very poorly hand-drawn )
   After the pictures,   I have  Attached a  'Word-Document'  containing the description of that  magnet-motor  from mid-2015
  If  my design from mid-2015,  does not work,  it could actually be evidence that  the magnetic-field  between 2 magnets( or just from 1 magnet ) is not composed of small-particles.
  Your diagram on post       http://overunity.com/15774/permanent-magnet-motor/msg476202/#msg476202   is actually the best diagram you have provided,  and all the different  magnetic-orientations  possible,  of the  moving-magnet( mine, and  stoyan's )  should be tried to see if any one functions.
stoyan_
Thanks for reply.
That,s my latest proposal. Easier to build, compared to my previous proposals
Now the ring is rotating and the rectangular shielded magnet is the stator.
I suggest using neodimium magnets.
BR.
