130 years old secret , your Pole transformer
Started by clearchrome, June 12, 2015, 07:49:37 AM
clearchrome
Quote from: MarkE on June 12, 2015, 01:42:12 PM
Pole transformers get warm.  The greater the load, the more they heat up.[/size]
I agree in most cases, specially for the single transfo. setup ...(the ones that blows up the most, https://www.youtube.com/watch?v=vRNI_uf4rcA because they tend to overheat fast )
Maybe its me but I noticed that the double transfo setup is in most case hidden from public view.
The laser in "laser thermometers" has nothing to do with measuring the temperature. It is only a "locator" to show the operator where the actual IR sensor in the unit is pointed. Since the laser emanates from an opening that is displaced from the opening of the IR sensor, the laser is only accurately indicating the location of the measured point at one specific range, usually quite close to the instrument (8 to 16 inches or so). Furthermore, the Canadian Tire unit has a "distance to spot ratio" of 8:1, which means that if you are 8 inches away from your target, the spot being measured is 1 inch in diameter. If you are, say, 30 feet away from your target, not only will the laser dot be completely away from the actual measured area, the measured "spot" will be nearly 4 feet in diameter.
http://www.canadiantire.ca/en/pdp/mastercraft-digital-temperature-reader-0574554p.html
Point one of these things at a pole pig "in the wild" and you will be "measuring" your sky. Use one within its proper accuracy range to measure a terminal at 15 kV potential and you are risking your life by standing too close. Some units are more or less susceptible to RF EMI; the one Morin uses is unduly sensitive to interference as is clearly shown in several of his videos. He should have bought the Princess Tire model, they are better shielded.
pomodoro
Quote from: clearchrome on June 12, 2015, 12:28:41 PM
So your conclusion is that its a big hoaks for him to attrack attention!?
is there a specific point that would prove that?
Have you ever met mad people? Most are quite normal , but they fabricate lies readily. From experience , I can tell you this guy is a fruitcake. Its that simple.  He's only discovery had been how to get the attention he so desperately craves by making up all of this crap.  Give the guy no more attention and he is likely to harm himself. Its harsh, but welcome to the real world.
ATOM1
                                                           I HAVE A RADIENT ENERGY TRANSFORMER !
There are many ways to cook up this energy sometimes its a hit and miss game depending where you live ! But I just want to point out that in the very early days of variable transforms the cores were made with iron that was not coated to prevent rust and there are 4 types of rust black brown red pink. Pink rust is most reactive to 02 and used in making very strong ferrite magnets in china,  to keep a very simple view of this is important for now so excuse the I am just a simple man routine...
I have a very old 2amp 275 v rated one but it sets up a 330v charge and if its at one metre off the ground when you switch it on and turn it off with the out put leads one inch off the ground than short them out it blows the 10 amp fuse in the plug and that's when its switched off....
To my utter amazement I connected one of the wires to a small 500 watt uni motor with neo magnets around it, it also had a aluminium head which tends to make a difference on the other side of the motor the remaining lead wire was put on a aluminium disc with plastic sheet on one side. When the final connection was made the mad little motor started up with some rather strange blue lights flashing an inch away from the brushes in the motor... I pulled the plug out of the socket which was already switched off!
But like a total idiot I reached over and  grabbed the motor as its about to fall off the table , It was like getting hit by a train and nearly killed me .....
This was only the beginning of the adventure with this transformer as what I did next is just far to magical for my lips to shed light of such a reality .... Since than I found the first recorded data for such energy way back to the late 17th century !
What tesla found is the same thing there really is very little to it and the higher the trans former is the more the power output ......... But its a deadly currant and I don't think its normal electricity or a static field energy ! To me its coming up from the plank level and has a frequency in the trillions of HZ...
Atom 1
FatBird
@ Atom
Please post a diagram or sketch showing how you hooked it up.
Thanks.
