130 years old secret , your Pole transformer
Started by clearchrome, June 12, 2015, 07:49:37 AM
ATOM1
There is nothing to it its the right hand rule ! Paint the picture in your mind !   The transformer sits on the table its plugged in the out put wires are 1 inch off the floor turn off the transformer and pull out the plug leaving one out put wire close to the floor The other connects to the motor than through the motor coils out the other side and onto a flat aluminium plastic coated  plate .. That's it and the motor just turns back on ....
But the trans former must have a rusted core or it wont hold a charge ????? You may find some old ones if your lucky but so far I got it working with a 2 amp 500 watt transformer ... My grid power is just over the 240 around 249v as I am close to the street transformer I get a little higher voltage.......
Also red oxide is banned from MUF IN THE UK and in many other EU countries but not in china If we could find someone who would make them its would be cool worth some good money but they are dangerous ..
An old energy system and a well known one but almost forgotten and I am sure not truly explored it will do many strange things and is thought that ghosts tap it to stay alive ....
ATOM1
clearchrome
Quote from: TinselKoala on June 12, 2015, 04:57:48 PM
The laser in "laser thermometers" has nothing to do with measuring the temperature. It is only a "locator" to show the operator where the actual IR sensor in the unit is pointed. Since the laser emanates from an opening that is displaced from the opening of the IR sensor, the laser is only accurately indicating the location of the measured point at one specific range, usually quite close to the instrument (8 to 16 inches or so). Furthermore, the Canadian Tire unit has a "distance to spot ratio" of 8:1, which means that if you are 8 inches away from your target, the spot being measured is 1 inch in diameter. If you are, say, 30 feet away from your target, not only will the laser dot be completely away from the actual measured area, the measured "spot" will be nearly 4 feet in diameter.
http://www.canadiantire.ca/en/pdp/mastercraft-digital-temperature-reader-0574554p.html
Point one of these things at a pole pig "in the wild" and you will be "measuring" your sky. Use one within its proper accuracy range to measure a terminal at 15 kV potential and you are risking your life by standing too close. Some units are more or less susceptible to RF EMI; the one Morin uses is unduly sensitive to interference as is clearly shown in several of his videos. He should have bought the Princess Tire model, they are better shielded.
Got a good point on that...give you the credit... how about the thermal imaging solution? Would you agree to be a good test?
ATOM1
You need oxides for radiant energy ! The transformer that this man is standing next to is old ! And its core has probable rusted making it  reactive to all elements including alpha particles ect ect ....... That is all it is !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Go back 130 years and make a transformer what iron are you using ???? Make a simple transformer with iron that rusts pink you will find what your looking for.....
ATOM1
MadMack
ATOM1,
Manganese oxide / iron oxide super cap?
Mack
ATOM1
I like the upper cap idea but nop you just need a basic varyac  AC voltage regulating transformer ! With a reactive core for radiant energy conversion to real power ... I have some old 1930 ones there cores are rusting hahah And that helps to trap a field stable flux on the coil when the lout put lead are of the ground at 1 metre .... SWITH IT ON THAN OFF ! Than pull the plug out touch the out put leads together and if its sparks you got a free radiant energy transformer ...
One out put lead need to go to earth the other through the load to a cap plat with one side coated with plastic best with a pate that has a high voltage applied thin sheet to it as they do when they rap it be for it goes to a manufacture... The hard part is making your own transformer ... In this simple set up the transformer is the dump coil for radiant energy ... The higher you lift the coil off the ground the more power it makes and if you increase the reactive core with isotopes the amps goes up .... probable many types of particles hit the transformer alpha particles and ions ect ect ...............................
Extremely high frequencies and voltage created but you can drop all that but be very carful work it out at a small load 1 metre off the ground ...
ATOM1
