Magnetic/gravitational motor
Started by Joao, October 09, 2006, 12:03:10 PM
Joao
I drew a new cofigura??o. A bicycle tire can be used.
ResinRat2
Joao,
This looks very clever and simple!
Two wheels may be the way to go; it would help add some Chaos.
It shouldn't be too hard to build a prototype.
Great idea.
CLaNZeR
Excellent Joao!
I have just done my 4th wheel here and loading it with springs to try get the same effect..
Never thought of using a tyre and adjusting the pressure to suit, maybe one to play with next.
Sean.
http://www.overunity.org.uk
aarnold
sorry.. i don't think it will work the repulsion from the others magnets will stop the wheel from moving. the magnets above and below will repulse from the center.. and will "balance" the wheel... my oppinion.. but I think you have to do it.. because the best way to try it's testing.
regards
Joao
I was thinking on the motor "B", and I arrived to conclusion that it does not work. The water, by no having points of ?support? inside of the wheel, will adapt to the total form of the wheel and the water will not transfer its weight to an only side of the wheel.
But the motor "A" still seems promising. It could be like the following figure:
