Friedrich Luling Magnet Motor
Started by DreamThinkBuild, July 05, 2015, 05:31:08 PM
Je sais : TOUCHÉ ! Avec ".....without serious ....." ! Context ! And writer/reader day-by-day priorities !
Quote from: Ufopolitics on September 14, 2021, 01:03:11 PM
IancaIV,
This Lüling Motor research and development is not to start "commercializing it" !!
To me, this Motor is beyond than using it to run a Home Generator...this is beyond searching for applications!!!
This Motor is based on Permanent Magnets on Rotor and Stator...which happens that our World Academy says, magnets have NO ENERGY...
Actually UNIKAT, An EXPONAT,Anti-"AXIOM"/THESIS -q.e.d.-DEMONSTRATION-MODEL for Your WORLD ACADEMY
I respect your over 20 years of research into magnetism...
        NOT ONLY !
I have been researching plus building magnetic motors, plus Electric Motors from SCRATCH, for also decades...so  what?
I have Patents in  the USPTO...so what?
                           Fine to hear,unrelated and unimportant ! But Your experience representing !
Probably You know that granted USPTO technical standart patents applications are often as WIPO application their international granting denied by the a.DE =german and b.EP= Munich-DenHaag PCT office !
        Not new !
Only to think about national "patent grant" worth international !
And the patentlawyer work related international research about "novelty" !
I assume 10 000+ patent/utility models publications with object "magnet motor"(only magnet !) and claims to find in the international archives ! 1870-2021
AND opposition period to patent grant is without time limit ever during "granted period" as wrong decision revisable  !
                Not good for bad informated investors and inventors (reinvented for the x time the same wheel!
                                      errare investors and inventors daily life est
This Motor could easily be built in Carbon Fibers, and composites fibers, like KEVLAR, Fiberglass...etc,etc...since it runs VERY COLD!!
Motor baking ? Layer-by-layer , Fibers :BAYER "plastics instead steel" ,ic-engine from plastics ,Ferrari chassis cheap ?
But you wrote:
So, you do not pay any importance That I have shown a Magnetic Motor that can go FASTER than Luling??!!...400+ RPM's?
After some hours thinking and writing and reading You should understand that "serious study" from a video/audio-information package is relatively "out of time ",for me !
serious=concentrated
I did not write that I will never deal with Your experimental offer !
400 RPM+ the Lueling prototypes,do You not assume that he also calculated with higher numbers and forces ? Car drive !
I can make a 3600 RPM Motor...based on Luling Tech...that simple...
See the HUGE difference, is that I not only can "research" but I CAN ALSO BUILD REAL MOTORS!!!
No,there is no difference in result : Your solution is expensive = ergo economical UNNUETZ/USELESS ,but as EXPO-/Museum-artefact to see !
There is NO PHYSICAL WORLD ACADEMY (in existence),also not "science united " !
Bye
energy is matter
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=4&ND=3&adjacent=true&locale=en_EP&FT=D&date=19931118&CC=DE&NR=4215818A1&KC=A1
also magnets represents matter ergo compact energy
idiotic WORLD ACADEMY members properly biogenerator conversion mass representing ,body energy recycling :
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=9&ND=3&adjacent=true&locale=en_EP&FT=D&date=19931223&CC=DE&NR=9312668U1&KC=U1
kolbacict
https://www-n--tv-de.translate.goog/politik/UN-Bericht-2-7-Grad-Erwaermung-drohen-article22811442.html?_x_tr_sl=auto&_x_tr_tl=en&_x_tr_hl=de&_x_tr_pto=nui,elem
https://patents.google.com/patent/EP1841544A2/en
5. The aircraft do not generates CO2 and do not contribute to earth warming process, on the contrary, it lowers the air temperature thus this engine is highly environmental.
  Hirshberg rotative external/internal energy conversion device with Lueling magnet motor as blade shaft drive !?
           earth average temperature decreaser ? more effective(physical/economical) than CO2 air scrubber ?
https://en.wikipedia.org/wiki/Virgin_Earth_Challenge#:~:text=The%20Virgin%20Earth%20Challenge%20was,materially%20in%20global%20warming%20avoidance.
Ufopolitics
Quote from: lancaIV on September 17, 2021, 04:00:11 PM
This cited Patent above is an AIR Wind Turbine based design...it uses INLET AIR to propel blades.
A completely DIFFERENT SETUP than Lüling Magnet Motor!!
Just like comparing Apples versus Bananas.
Lüling uses Air as an ASSISTING SYSTEM, not as a MAIN SYSTEM TO SPIN THE ROTOR.
In my Video I demonstrated CLEARLY, that Air is used TO BRAKE, SWITCH OFF, the EQUILIBRIUM that NEUTRALIZATION DOES to Opposed Magnetic Forces.
Pneumatics, in Lüling case, is just like Electric Ignition does in the ICE Engine, it assists for the Engine Fuel to Explode...HOWEVER, as in DIESEL ENGINES, Ignition Timing is NOT REQUIRED, except to start the Diesel Engine, once it warms up, it starts without the GLOW PLUGS.
AND PLEASE, READ ME WELL, IANCAIV:
I AM NOT HERE TO ARGUE WITH YOU NOR ANYONE ELSE!!
I AM NOT HERE TO "WIN" ANY PRICES!!, BECAUSE I DO NOT GIVE A DARN THING ABOUT IT.
I am not here to compare Lüling to ANY other Patent out there!!
I am ONLY here to TEACH WHOEVER IS INTERESTED to know more about Lüling, or want to build my setup, I will help ONLY REAL BUILDERS, who can prove me their prior work.
I DO NOT WASTE MY TIME WITH "THINKERERS" THAT DO NOT BUILD NADA, NOTHING!!!
CAPISCI?, COMPRENDE?, COMPREND PA?, UNDERSTAND?
Great, so do not waste your time answering my post here.
I APPRECIATE IT
Ufopolitics
P.D: Magnets are NOT just "Simple Matter"...Magnets have Polarization and far more complex characteristics than PLAIN Matter...
"Matter is Energy" is an ABSTRACT from the "Theory of Relativity"...NOT APPLIED when it comes to Permanent Magnets...again, Apples and Bananas
Principles for the Development of a Complete Mind:Study the science of art. Study the art of science.
Develop your senses- especially learn how to see. Realize that everything connects to everything else.
―Leonardo da Vinci
AND PLEASE, READ ME WELL, IANCAIV:  ;)  I-A,wuenschte sich der bajuwarische Esel
The Hirshberg device/machine uses as drive a motor (pneumatic/combustive/electric/....... )  Look its "mosaics" !
https://worldwide.espacenet.com/publicationDetails/mosaics?CC=CN&NR=104047814A&KC=A&FT=D&ND=3&date=20140917&DB=EPODOC&locale=en_EP
the closed heat pump cycle in conjunction with the Ranque-Hilsch tube process : rotative
          Verstand,verstehen und daraus Vernunft     Mind,understand and from it reason    :
https://www.mpg.de/7940256/koordination_sprechen_denken
https://www-mpg-de.translate.goog/7940256/koordination_sprechen_denken?_x_tr_sl=auto&_x_tr_tl=en&_x_tr_hl=de&_x_tr_pto=nui,elem
First think, then talk?                                                           First read 1x,2x,3x,think,1x,2x,3x and then talk about it !
For the temporal coordination of speaking and thinking                                        / and reading
https://www-wissenschaft-de.translate.goog/umwelt-natur/wie-wir-denken-und-sprechen-koordinieren/?_x_tr_sl=auto&_x_tr_tl=en&_x_tr_hl=de&_x_tr_pto=nui,elem
                     including ultra-learning and ultra-working results ! CONCENTRATION !
btw : First think, then talk                     tribunal-level : think,decide(Yes,No,left,right,...),judge(= justify !)
  bible-order ( bible : ancient Constitution,judge  breview) ! Evangelist Matthaeus
wmbr
Lanca
poste scriptum : CAPISCI?, COMPRENDE?, COMPREND PA?, UNDERSTAND?
                         italiano    hispanics           france/french     anglo-saxonic       I glov es ,deutsches Platt ;D  ,saxonischer Infinitiv : glauben
                       https://latin.cactus2000.de/showverb.fr.php?verb=capere
                       https://latin.cactus2000.de/showverb.fr.php?verb=prendere
                       https://latin.cactus2000.de/showverb.php?verb=stare
                        COMPREND PA?                    Je comprends pas                          PA/O = der Stab,the Staff,der Knueppel
        Je ne comprends pas
I DO NOT WASTE MY TIME WITH "THINKERERS" THAT DO NOT BUILD NADA, NOTHING!!!  I clearly also not !
P.D: Magnets are NOT just "Simple Matter"...Magnets have Polarization and far more complex characteristics than PLAIN Matter..."Matter is Energy" is an ABSTRACT from the "Theory of Relativity"...NOT APPLIED when it comes to Permanent Magnets...again, Apples and Bananas
Somebody wrote about "simple matter" versus "complicated matter " ?
        "Matter is Energy" ,   e=hv=hc/λ
    this represents  only 1 from 3 differrent formulas in Klaus Rassbach " new matter " document/application
https://www.britannica.com/science/matter
matter, material substance that constitutes the observable universe and, together with energy, forms the basis of all objective phenomena.
At the most fundamental level, matter is composed of elementary particles known as quarks and leptons (the class of elementary particles that includes electrons).
Quarks combine into protons and neutrons and, along with electrons, form atoms of the elements of the periodic table, such as hydrogen, oxygen, and iron.
Atoms may combine further into molecules such as the water molecule, H2O.
Large groups of atoms or molecules in turn form the bulk matter of everyday life.
also Apples and Bananas are as matter energy                     ,volume,Kg,colour,aroma,.......
