Friedrich Luling Magnet Motor
Started by DreamThinkBuild, July 05, 2015, 05:31:08 PM
dom444
it is correct except its not every second revolution, turning clockwise at the 47 sec mark it attracts the rotor plates in turn ( there are 2 plates), as they approach the magnet it then releases them when the blocks are in place at the end of there travel, if not neutralized the magnet would grab the turning plate as it trying to leave and hold it.
otherwise you are correct.
I am using VLC free media player if you repeatedly press the playback slow tab you can slow it down to as slow as you like then you can see what is going on as the machine moves to fast to work out otherwise
dom444
dom444
I suggest we make this an open source project as this is the one magnetic motor where you have a working demonstrable model that was built, my preliminary experiments show the principles are sound
and i am working on a model now, but any help would be appreciated as i said there is research and development involved, as there are variables  and may take a few tries to get it to operate
properly.
If anyone does the experiments please share results so we can move forward, if anyone has experience with magnetic modeling it would be good to see the magnetic pattern with the influence of steel blocks around a magnet both shielded and unshielded,
thanks Domenic
Kator01
Domenic,
you are right I used the ( -) key while watching the vid with the vlc-player: there are two accelleration events.
One remark:
the blocks are back in neutralizing-position already in stage three ( image 3 )
Mike
dom444
yes you are right was a split second before they where retreating back didn't quit capture it, it moves very fast.
