Friedrich Luling Magnet Motor
Started by DreamThinkBuild, July 05, 2015, 05:31:08 PM
synchro1
The pneumatic version does not use the same shield effect. The builder substituted the compressed air force to power the unlatching.
Look closely at Luling's schematic and you will see he rocks a ferrite keeper to the side to unlatch the attraction. This puts the shear force to work rather then the brute pull apart of the magnets by compressed air force.
The attraction is to the backing magnet behind the ferrite. This is the single most important thing to understand about this type of motor.
It would require very little pulse power to neutralize the ferrite with an electric coil. An attraction Bedini in Adam's resonance would be equally overunity.
A high perm ferrite "Orbo" style toroid would attract and neutralize the opposite magnets with the greatest minimum of power. The input power to run four finely tuned Luling motors at full speed with "Orbo" neutralization coils would not lift the needle off the resting peg of an amp meter.
conradelektro
Quote from: Ufopolitics on September 06, 2021, 12:47:36 PM
Lüling Motor does not uses electromagnets, nor any electricity to run,...and that is the main point...
The moment that an electromagnet is utilized, it is just another Electromagnetic Motor, out of the thousands types and models out there...period!!
Now find me out there, a Magnetic Motor, that only uses Permanent Magnets and Compressed Air...none, except Lüling.
Hello Ufopolitics,
compressed air has to be compressed and that costs energy. I gues you use a compressor driven by an electric motor.
Does the Lüling Motor generate more energy than is necessary to compress the air which keeps it turning?
It is difficult to measure, but it should be measured.
Do you claim overunity?
Greetings, Conrad
synchro1
The Luling compressed air motor rotor does two entire reveloutions from one release! Luling's repulsion force must be thousands of times greater than any shearing force that might be expended by a neutralizing Orbo pulse. It looks like the builder keeps the attraction magnet retracted for the second rotor round. This would require two pulses of the Orbo coil.
Half Luling's Power must come from the attraction force. A second Orbo coil would turn it into a KeYho masking attraction design.
synchro1
Looks like this. An Alnico Flynn would work well to latch off with double neos between the two 3 stator pairs.
Ufopolitics
Quote from: conradelektro on September 06, 2021, 02:16:09 PM
Hello Ufopolitics,
Greetings, Conrad
Hello Conradelektro,
Nope, I did NOT claim Overunity...since I need an external source of Energy to operate it...
Not yet...hahahaha
You are right, Air needs to be compressed...but what a simple operation man!!...compared to "building" some gasoline or Diesel Fuel to fill your tank in order to run your car Uh?
There are ways to use a compressor as Closed Pneumatic System...it is already out there...the suction part of compressor is done from a low pressure tank...where all the air pistons and valves exhaust to...while the high pressure tank supplies the required psi to keep system running. Compressor has two functions here...as a purge valve from low to high tanks...and as compressor of air... ;D
And yes, of course a secondary air motor could also be running just the compressor.
Ufopolitics
Principles for the Development of a Complete Mind:Study the science of art. Study the art of science.
Develop your senses- especially learn how to see. Realize that everything connects to everything else.
―Leonardo da Vinci
