Thanks to ALL for your help!!
Finally magnetic heater DIY for FREE
Started by dakanadaka, July 12, 2015, 09:10:28 AM
forest
Resistance heating elements are beauties in simplicity and low cost. They create however a lot of  problems, due to water residue minerals attracted to the surface, and the internal temperature os such element is very high and once the mineral deposit on the external wall is built this temperature even rise and is the reason of malfunction.
Now , induction heaters can solve much of those problems.
offtopic:
I  have a few questions about resistive heaters used for AC power. MarkE,can I ask you ?
dakanadaka
Ok Tnx for all math and reply... Today I hope I will take the water out of the copper box to see how much exacly oil does it contain and then I could then conclude exacly how efficient this heater is and then try to make more efficiency :)
This project cost me a lot to research it and do it on my own and the thing was there are people on the youtube that are showing this kind of heaters, but no one showed exacly how can it be done with all math on efficiency etc.
I saw one patent on it on air heater and there is one german guy who is searching for investitors, but no one who gave everything to the public and then we all could profit and help each other to make it even better, so that is what I want to achieve to share and to help each other to build more efficiency.
Im not saying that this path could lead to nothing then research that we couldnt achieve nothing more then 67% of efficiency, but then other people dont have to go so far as I did with financiel costs :)
So one more question that could help me on this trip:
Do you have any tip on how to inprove efficiency of this kind of heating system or any research already done on this?
I saw electrical existence heater and yes they are saying 98%, and I also build the friction heater and didnt go much ferder on it, but I miss that guy on youtube oliepigg username he just dissappierd with his friction heater :(
MarkE
Quote from: forest on July 13, 2015, 04:21:43 AM
The mineralization issue occurs in water heaters with an insufficient sacrificial anode.  We are talking about an oil heater.  Mineralization is not an issue.
The internal temperature of a resistive heater element can be whatever one chooses from just above room temperature to well over 1000C.  Hotter transfers more thermal energy for a given size heating element.
Induction doesn't solve a problem that doesn't exist: mineralization in an oil heater, or higher working temperature than is desired in the heating elements.
offtopic:
Do you mean resistance heaters powered by AC?
MarkE
Quote from: dakanadaka on July 13, 2015, 05:09:36 AM
Hydrodynamics have built a mechanically driven cavitation heater for years.  At one time they thought it was overunity because they did their calculations based on the wrong feed water temperature.  If you want to heat efficiently, then no matter what you use as the heat source, you need to insulate that and your heated output from the local environment.
dakanadaka
Quote from: MarkE on July 13, 2015, 06:44:21 AM
Do you mean these guys: https://m.youtube.com/watch?v=yh_-DUKQ4Uw ?
And what about this solution:
https://m.youtube.com/watch?v=A5llLsfZYXw does anyone knows how to build this one?
