I have a working machine
Started by Rall, July 18, 2015, 03:52:38 PM
seychelles
ARMCORTEX YOU AFTER ALL THESE YEARS OF HARD RESEARCH AND EXPERIMENTING,
YOU CAN NOT TELL ME YOU HAVE GIVEN UP ON FREE ENERGY..
YES A PMAGNET CAN DO WORK AND DOES DO WORK. 1 MAGNETRON ,THE RF OSCILLATOR TRANSMIT THAT IS USED IN YOUR MICROWAVE OVEN WILL NOT WORK IF THE PM IS NOT PART OF  IT ,IT IS THERE TO FORCE THE ELECTRONS TO SPIN SO TO START THE OSCULATION NEEDED. 2, PERMANENT MAGNET ALTERNATOR IS WAY MORE EFFICIENT THAN ELECTROMAGNET ROTOR TYPE
3. ELECTRIC MOTORS WITH NIBS MAGNETS IN EVS...
seychelles
TO PROVE THAT A PERMANENT MAGNET IS A FREE ENERGY DEVICE. LET US SAY THAT A NIB HAS A MAGNETIC
STRENGTH FIELD OF 1 TESLA. WHAT WOULD IT TAKE TO GENERATE THAT TYPE OF STRENGTH FIELD
AROUND AN ELECTROMAGNET, THAT IS HOW MUCH ELECTRICAL POWER IS REQUIRED TO MAINTAIN
THE SAME I TESLA OF MAGNETIC FIELD STRENGTH . FOR THAT NIB PM THE MAGNETIC FIELD CAN LAST YEARS
WITHOUT ADDING ONE WATT OF ELECTRICAL POWER..SO MY CONCLUSION IS THAT A PM IS AN ATOMIC
RESONATING SPINNING OSCILLATOR..
Vickysong
hi, can you share more details what's your machine can used for?
www.hkinventory.com
endlessoceans
Quote from: seychelles on August 20, 2016, 01:29:49 PM
Like so many others here, it is your REASONING that is flawed.  For the record I applaud experimentation.  What I don't see of value is erroneous COMMENTS based on idiotic reasoning.  Blatantly WRONG comments waste other peoples time because they could be doing something more useful.  Marshmallows are white, soft and fluffy but they are not made of clouds!!  LOL
You say that a Perm Magnet is OU because it currently is able to exert force that would otherwise cost a lot of electricity if it were an electromagnet.  Wake up!!  At one stage when they made that Permanent magnet, an incredible amount of energy went into sintering it and aligning the domains.  After that it is a static force.
Let me illustrate......take a standard nut and bolt.  You now get a wrench and tighten that nut and bolt until there are thousands of pounds clamping force compressed between the two.  You have expended energy to do that and it is now 'stored' between the two surfaces.  Is it a free energy device????????????????????????????   Is it OU?????????????????????   NOOOOOOOOOOOOOOOO!!!!    It is a storage device!
Another example.  You take a empty bottle.....you compress a gas and now have a static storage device.  If you open the valve of the bottle and let the gas out some of the energy that was expended compressing it can be recovered.  BUT can you recover more than what it took to put the gas in the bottle??? NO NO NO NO.
Wake up....Wake up...Wake up.   Stop being such a simpleton.
There are laws that are bound up and locked tight in this Universe for our protection otherwise we would have runaway chemical reactions happening all around us which would have resulted in the Planet and Stars imploding a long time ago.
