PLASMA BALL LIGHTS UP 50 WATT LED LAMP VIDEO
Started by magnetman12003, July 27, 2015, 10:21:53 PM
magnetman12003
OK Folks,
I have been experimenting with a common 6 inch diameter plasma ball and here is an interesting video.  Now to do this with hands off.
https://www.youtube.com/watch?v=zK9SPpdy-io
Bruce_TPU
This is my replication of Tom's experiment....
https://www.youtube.com/watch?v=R4tU3Tvoqu4
Thoughts, Tom?
Cheers,
Bruce
