'Impossible' rocket drive works and could get to Moon in four hours
Started by Pirate88179, July 29, 2015, 01:12:10 AM
gravityblock
In order to go straight up, then the vacuum is produced on the top portion of the craft, and the craft will be impelled into the vacuum from the atmospheric pressure underneath.  The craft will always be facing a wall of less than 1 atmospheric pressure as it moves, thus there is no worry for structural damage, fatigue, or being torched.  In addition to this, sound doesn't travel in a vacuum, thus there is no sonic booms associated with these crafts.  There's no g-forces when an object is pulled from the front and is pushed from the back with an equal force.
Gravock
gravityblock
If there's low pressure on one side, the other side is subject to the full atmospheric pressure.   With an atmospheric pressure of 1.033 kg. per sq. cm. we can calculate the force operating on a saucer of 20 m. diameter is equal to 3,278,272.8 kg.The cathode rays intersect the anode rays at an angle of 45 degrees. This is achieved by using high voltage and current.  If you wish to go very fast, then use an absolute vacuum.  Use a semi-vacuum to move more slowly. The intensity of the vacuum is proportional to the current used and is controlled by a rheostat. If you want to follow an undulating course, then use a pulsing current.
Gravock
gravityblock
Quote from: synchro1 on July 29, 2015, 01:56:05 PM
Brown-Biefield effect. There's a thrust in a capacitor toward the negative charge plate too. The plasma produces a magnetic field.
Other than the Brown-Biefield effect being misunderstood, you are absolutely correct!
Gravock
gravityblock
It's amazing how a simple aluminum window can easily convert the EmDrive from a closed system to an open system, just like turning the fan 180o on the boat with a sail.  By hiding the aluminum window from the public, then it falsely gives the perception that it is a closed system, and then it no longer supports the claims made for the open system with the window.
Gravock
Hope
