Transformer Related Question ??
Started by magnetman12003, August 08, 2015, 03:30:12 PM
magnetman12003
I have a hi frequency  transformer with a secondary of 2200 ohms and a primary of 25 ohms.
Notice the 88 to 1 ratio.     I have a power supply that puts out 1232 volts AC and wish to see 14 volts AC output.  Notice the 88 to 1 ratio again.
Question:  Can I connect the  transformers secondary to the power supplies 1232 volts and see 14 volts AC out of the primary?
The question is a learning curve for me.
MarkE
Quote from: magnetman12003 on August 08, 2015, 03:30:12 PM
Transformer impedance changes as the square of the turns ratio.  Voltage changes proportionally to the turns ratio.   88:1 impedance is about 9.4:1 turns ratio.
forest
MarkE
Would that mean 1:1 transformer is always 1:1 ?
MarkE
Quote from: forest on August 09, 2015, 04:11:52 AM
MarkE
Ignoring losses, yes.
pomodoro
Those values are actually the transformer specs, not what you measured with a multimeter, correct? If so, then all is good. Also, if its a HF transformer, make sure you use it only at HF.
