A NEW 'MAGNETIC-BEARING', INVENTED TODAY
Started by guest1289, August 12, 2015, 04:55:23 PM
guest1289
The  image in the  URL  below,  is not the NEW 'MAGNETIC-BEARING',  INVENTED TODAY ,  but it is the basis of it.
http://overunity.com/6048/using-magnets-instead-of-bearings/dlattach/attach/27840/image/
A  new type of  magnetic-bearing  could be based on the above principle in the image at the  above  URL ,   and instead   of  'flattish-round magnets',   magnetic-tubes/pipes   could be used,  for example,  4 pipes arranged in a circle,  and the  'bearing' or  moving-part  spins in the middle of the circle    )
(   Now I don't know what to do,   I am totally tired out from the process and problems of filing a   'provisional-patent-application'  for  'MY OTHER INVENTION'  related to this (  I cannot sneakily add this NEW-INVENTION  as modification to my   'provisional-patent-application'  for  'MY OTHER INVENTION',   because modifications are not allowed on  'provisional-patent-applications'  .
     The patent system,  is keeping  everyone down (  because they try to turn the government  patent-departments  into profit making businesses,   and the result is that the  'average-individual'  loses reasonable access to patenting their  intellectual-property    )
MarkE
Quote from: guest1289 on August 12, 2015, 04:55:23 PM
First: Please stop spamming by opening multiple threads on the same subject.
You also cannot obtain a defensible patent on prior art.  If you are trying to attract investors or some such thing then you will need to explain to them what problem it is that you solved, and why you were able to solve it and others before you did not.
guest1289
I only started a new   thread   because to me it does in fact appear  'obvious'  that  today I have invented a   'NEW 'MAGNETIC-BEARING',  which is distinct from  'MY-OTHER-MAGNETIC-BEARING-INVENTION',  in that this  'NEW 'MAGNETIC-BEARING'  has the full versatility to be used in all applications that other  'magnetic-bearings'  are normally used in  (  due to a  sufficiently  different design from  'MY-OTHER-MAGNETIC-BEARING-INVENTION'  )  .
MY OTHER REASON FOR CREATING  A NEW  THREAD,   IS BECAUSE IT IS THE BEST WAY OF MAKING THE OTHER  INVENTORS  ON THIS SITE  IMMEDIATELY  AWARE OF  THIS   'NEW 'MAGNETIC-BEARING'.
IT,  COULD FOR EXAMPLE,  PROVIDE A SOLUTION TO PROBLEMS THEY HAVE BEEN TRYING TO SOLVE.
(   It fell into a  grey  area,  of whether or not to create a new thread  )
(  I have observed  the consequences for this site resulting from the  unnecessary  creation of new threads,   and threads created to attract investors for  fraudulent  inventions( where not all the details of how the invention works are disclosed ),    and new threads created to discuss subjects which are  irrelevant  to this site ( as entertaining as they are  ) .
The only  thread  I have ever created  unnecessarily,    was the one  regarding  a  'non-electric-permanent-magnet-powered-faraday-motor'  ,    because   'I DID NOT KNOW'  that that subject was already being discussed in another thread called   'Permanent magnet motor',   I had not seen that thread before,   and I thought that  specific designs  of  'magnet-motors'  had their own thread.
If anyone wants to contact me to   'write and draw and file'  my 'patent-application'  for  todays invention,  AND  address the  'financial-costs' associated with that process ,    CONTACT ME at   john.backerwww@gmail.com
guest1289
Below is  an image of  this  NEW 'MAGNETIC-BEARING',  I INVENTED TODAY
(  It's  obviously  'incredibly' simple  )
In the  image  below,  at  the  point  labelled at the bottom of the image as   'POINT X' ,   there would be a  'magnetic-cradle'  such as the  one in  my other  invention  http://overunity.com/15966/my-levitating-object-invention/msg459006/#msg459006  ,    to keep the   moving-part   of the  magnetic-bearing   in place in the opposite  90-degree angle,   to make it a  100%  magnetic-bearing,  unlike others.
(  This can function in all the  applications  where all other  magnetic-bearings  can function in,  which makes it different to my  'OTHER MAGNETIC-BEARING-INVENTION'     http://overunity.com/15966/my-levitating-object-invention/msg459006/#msg459006  ,   but that invention has it's own  significant  advantages   )
Your magnetic bearing ideas won't work, neither this one nor the other one. You have not found a way around Earnshaw's Theorem at all. Your  system is unstable as others have already pointed out to you. I suggest that you "curb your enthusiasm" until you have done some experimentation for yourself and have constructed some prototypes or testbeds. You may learn a lot by doing so.
There are several ways that magnetic levitation/non-contact bearings can work.
One is stabilization through rotation (like the Levitron toy).
Another is active stabilization using electromagnets and feedback loops.
A third way is to use superconductivity, flux pinning (Meissner effect).
Levitron-type systems are dependent upon very careful adjustment and spinning to stay in the "sweet spot" for levitation to occur. The "Mendocino Motor" system needs one small contact point to stabilize the system so it will work. Steorn used this type of magnetic bearing in their Orbo designs. Active (electromagnetic, feedback-stabilized) magnetic bearing systems are used in a number of commercial applications such as high-end turbomolecular vacuum pumps. Superconducting systems need active cooling which adds to complexity and cost.
