A NEW 'MAGNETIC-BEARING', INVENTED TODAY
Started by guest1289, August 12, 2015, 04:55:23 PM
guest1289
The simple ones  function(  where they just rest on the  'two'  magnets etc ),  there are numerous  genuine youtube videos,  showing them working with no problems,    examine the image at the  URL  below  .
(  I WAS worried that  using more than  two  magnets,   would not function the same as the simple ones,   BUT NOW I HAVE REALIZED THAT IF THE  DIAMETER  OF THE  MOVING-PART ( IN THE MIDDLE OF THE BEARING )  IS LARGE ENOUGH,   THAT IT WILL FUNCTION   )
http://overunity.com/6048/using-magnets-instead-of-bearings/dlattach/attach/27840/image//
(  your browser may only download the image above,  and then you may have to click on the  download  to  view it  )
NOW,  GO TO MY INVENTION   http://overunity.com/15966/my-levitating-object-invention/msg459006/#new  ,   THEN GO TO THE FIRST PAGE OF THE THREAD,  AND GO TO THE POST ON   'August 11, 2015, 06:33:51 AM'  ,  AND  EXAMINE  THE IMAGE  LABELLED   3_V magneticTrack.jpg   ,     AND TELL ME      THAT IF THE    'LEVITATING-OBJECT'  WAS  A  FULL-RING  LEVITATING  ABOVE THE  TWO-RINGS  IN THAT IMAGE,      THAT THAT WOULD NOT WORK,   IF IT WAS JUST SET UP ON A STEADY TABLE     ?
MarkE
Please stop with the all caps.
If you think you are going to get anywhere then at least for yourself come up with what it is you think you have that is unique, why you think it would work, and why you think no one thought of it before.  If you thnk you have good answers to all three questions then you can start working on analyzing / modeling it, and/or building a prototype.
Quote from: guest1289 on August 12, 2015, 08:43:22 PM
THIS IS THE "MENDOCINO MOTOR" SUSPENSION SYSTEM. IT REQUIRES ONE POINT CONTACT FOR STABILITY. WITHOUT THIS CONTACT THE ROTOR WILL SIMPLY CRASH INTO THE SUSPENDING MAGNETS. THIS IS IN FACT A DEMONSTRATION OF THE TRUTH OF EARNSHAW'S THEOREM.
HERE IS A VIDEO OF MY ELECTROSTATIC MOTOR USING THAT SUSPENSION SYSTEM:
http://www.youtube.com/watch?v=tVfw-TeJ9r4
THAT IS RIGHT, IT WILL NOT WORK. BUILD IT YOURSELF AND FIND OUT WHY NOT. DON'T SMASH YOUR FINGERS!
(It might work if you can spin-stabilize the "levitated" magnet properly. Then you will have invented the Levitron.)
YOU SAY YOU "CAN'T BUILD ANYTHING"... I WONDER WHY NOT? WHAT IS PREVENTING YOU FROM ORDERING SOME MAGNETS FROM A SUPPLIER AND PUTTING THEM TOGETHER IN WHATEVER WAY YOU LIKE?
AND ALL_CAPS IS CONSIDERED "SHOUTING" AND IS NOT NECESSARY TO GET YOUR POINTS ACROSS. SEE WHAT I MEAN??
guest1289
Thanks for identifying it,   by telling me the name of it ( MENDOCINO MOTOR" SUSPENSION SYSTEM ),  that is a big help for what I'm doing .    (   I did not know it will crash without   'One point of physical contact for stability' ,   amazing   )
(  I may have slightly misunderstood  regarding that  it will crash without   'One point of physical contact for stability'  ,    Since you only said  'One point of contact for stability'  ,   you did not say  'physical contact',   but I'm going to examine it   )
Soon,   I will examine it properly( the MENDOCINO MOTOR" SUSPENSION SYSTEM ),    just to assure myself  that the    'One point of physical contact for stability'   required by the   'Mendocino Motor Suspension System'  ,    cannot infact be replaced by a  contactless  magnetic-bearing,   based on the same principle as this  'Suspension System'  ,    For Example,   by putting a    magnetic-ball  on the  very end of the  axle,   and  then using the same principle as this  'Suspension System' to  repel  the  magnetic-ball (  but,  by using  2  pipe/tube-shaped-magnets   instead of  flat-round-circular-magnets,   to repel the  magnetic-ball   )
The  ring  levitating  above the  2 rings( in my levitating object invention  ),   could just be made of plastic,   and at every  90-degrees around the circle,   it could have  something like  a   magnetic-ball  to  levitate it  above the  2  rings (  4 balls in total ).
     But,   instead of a   full-ring   floating  above the   '2-rings',   it could just be something like  a  single    'magnetic-ball( which has a small stick containing a small weight extending from its underside to keep the magnetic ball pointing in one direction to maintain repulsion  )   levitating above    the   '2-rings'.
(   Although I believe everything you have told me,  I'm not totally giving up  )
(  I can't go into the details why I can't build anything  )
(  I'm already reducing my use of  text all written in capital letters  )
(  Hopefully,  you are right,  and I will not have to waste anymore time on my designs that you have seen,
_________
You could,  if you wanted to,  try and  debunk my   'magnet-motor' ,  in the
the thread I created for it     http://overunity.com/15860/can-anyone-identify-this-mystery-magnet-motor-or-provide-any-information/msg454866/#msg454866   ,   and in particular,   the  'drum-version'   of it on the first page of that thread  posted on   'July 10, 2015, 12:06:20 AM'   ,  in image    'DRUM VERSION.JPG'  ,
____________
But regardless,   your information has been very useful,  theres nothing worse that wasting time on things that other people already know cannot work
Quote from: guest1289 on August 12, 2015, 10:58:29 PM
Yes, it has to be a rigid, physical contact.
No, unfortunately that won't work. You'll notice that the "MM" suspension system has a sharp point, bearing onto a piece of glass, for very low friction. The levitation magnets need to be adjusted so that the rotor axle's point bears gently on the glass. If this point-contact has any flexibility, the rotor will crash, since it is being simultaneously attracted and repelled by the lower supporting magnets on the frame, and must be precisely fixed in position axially with respect to the magnets on the frame. People have tried using magnets on one or the other or even both ends of the axle to attain this fixed position, but it has never worked because of the "springiness" of the magnetic attraction or repulsion. The rigid point-contact is the only way that has been discovered so far to make the suspension stable.
Steorn's variant of this system used a vertical axle and very strong ring magnets, concentrically positioned on frame and axle, with the "point contact" being a hardened ball which bore against the hardened face of a micrometer adjusting screw. By adjusting the mike, the proper axial position could be set and maintained at a low-friction but axially stable position.
All of that being said, these systems are fun to experiment with and I am encouraging you to do some experimentation of your own, if and when you are able. Perhaps you can find a new arrangement that hasn't yet been tried. But as I said earlier, as long as you don't have some kind of prototype, and are covering ground that has already been well explored, you might think about holding off on making big claims, and especially, I'd advise that you don't spend any money on patent lawyers...yet! Wait till you have a proof-of-concept prototype constructed that works as you think it should.
_________
Thank you for not using all-caps routinely.
I think, as I said earlier, that rotational (spinning) stabilization might work with your ring magnet arrangement, but again, this would then be a variation on the Levitron, and those things are pretty hard to adjust properly. When they are, they are pretty amazing for sure, but they can't really take any appreciable load like a real _electromagnetic, feedback-controlled_ levitating bearing system can.
It's my strong belief that your system as described would only produce "crashes" as the object you are trying to levitate slips out of its required position. The situation is kind of like trying to balance a marble on top of a bowling ball. There "may" be one exact point where you could balance the thing, but the very least slightest perturbation or vibration or off-center situation will make it "diverge" and crash. With magnets it's even harder -- in fact, as Earnshaw proved, impossible -- because of that "springiness" thing.
____________
Yes, I saw that earlier. The problem is that the strength of attraction of a magnet falls off rapidly. So there's an equilibrium position of the rotor magnets that will not cause any rotation. You could probably rotate the rotor by hand with very little "cogging" but there's no reason that it should rotate on its own. Furthermore, the system will actually act as a brake, due to eddy currents that are generated in the stator as the fields of the rotor magnets are dragged through the stator material.
But build it and see for yourself! Perhaps some pulse-motor builder can take an already-built rotor and wrap a length of iron barstock around it for a stator. It should be very easy to see if there's any tendency to rotate, simply by doing rundown tests in both directions. If you can't build anything at all, for some reason, maybe you could hire someone to do it for you, or you could ask some specific individuals to make and test it.
My problem is sort of the opposite of yours. I _could_ build many things, and have done so. But much of my machine tooling is out of reach, and I can't spend even a few pennies on projects like yours. But it wouldn't be very hard to do, especially for someone with a lathe and milling machine and other basic machine shop tools.
And just for fun:
http://www.youtube.com/watch?v=zPqEEZa2Gis
