STROBE GLOBE FREQUENCY POWER VIDEO
Started by magnetman12003, August 13, 2015, 07:54:08 PM
Bruce_TPU
My response to Tom's magic plasma ball.
Another fraud claim.
Tom, my bill is in the mail
https://youtu.be/R4tU3Tvoqu4
Cheers,
Bruce
