New reactionless motor from India
Started by pomodoro, August 15, 2015, 07:43:38 AM
gravityblock
Quote from: gravityblock on August 17, 2015, 03:15:35 AM
Your postulate above is based on a false assumption.  Trying to self-loop a system introduces additional resistant forces that were not previously there.  Such as deceleration, inertia, negative torques, and negative forces, etc. which acts against the system itself in which you're trying to self-loop.  In other-words, your postulate is based on a false assumption that there are no resistant forces introduced to the system that acts against the system itself when trying to self-loop it.
Gravock
MarkE and his minions can no longer use the argument that a system isn't COP > 1 if it can't be self-looped.  That argument is wrong based on a false assumption, as previously shown.
Gravock
gravityblock
Quote from: gravityblock on August 17, 2015, 04:06:11 AM
Gravock
Work can be done with no energy if that work is being done internally within the system itself.  However, if a system is doing work that is external to itself, then it requires energy to do that work.
Gravock
gravityblock
Quote from: gravityblock on August 17, 2015, 04:52:07 AM
Gravock
AC,
This means inertia acts within and upon itself, and it requires no energy to do so.
Gravock
MarkE
Gravock
LOL, it's straw man days again.  Set-up and slay arguments that you have invented.
As if you didn't already know:  COP is a figure of merit for heat pumps that measures the amount of heat energy moved relative to the energy expended moving that heat energy.  A 100% efficient heat pump moves N Joules of heat while expending zero Joules.  It would therefore have a COP of N/0 which is undefined.
Next time please try a bit harder.
gravityblock
Quote from: MarkE on August 17, 2015, 05:08:21 AM
Call it whatever you want, but it doesn't change what it is.  Most people have adopted the analogy of a heat pump's COP to represent a system that is greater than unity.  I replaced COP > 1 with OU in my statement below.
MarkE and his minions can no longer use the argument that a system isn't OU if it can't be self-looped.  That argument is wrong based on a false assumption, as previously shown.
Gravock
