A sincere gentleman sharing a magnet motor build .[NDA issues??]
Started by ramset, August 26, 2015, 08:37:49 AM
Quote from: tinman on December 01, 2015, 08:11:16 PM
Ohhhhh dear Chet-->really :o UFOpolotics.
His video clearly shows you !once again!  just how clueless he is in what he is doing,and what he is seeing in his results. He shows nothing more than a magnetic field varying in time-the very thing needed to create an EMF across an inductor-be it that single turn copper plate,or the multi turn coil.
The magnetic field changes in time in regards to the position of the coil when he drop's the steel core on top of the magnet. Once again DUFO shows nothing out of the ordinary. In fact,i cant believe he dosnt understand as to why the spike is the same when he turns both the magnet and coil over.
Next video,he will turn his scope upside down ,and show us how the spike is now inverted.
UFOpolotice clearly belongs at energetic forum :D
Brad
Exactly. UFOP is showing his ignorance and is actually _confirming_ the conventional viewpoint, as others are telling him in that thread. He has tried to construct a demonstration that "proves" Kenny's theory, rather than designing a true experiment that could potentially disprove it. And he has failed even in that.
Wheeler's ideas are fanciful art, or rather cartoons, nothing more. Have any of the Believers actually put his "heat emitting overunity" bismuth ball-plus-magnet into an insulated container with a thermometer to see if the temperature rises yet? That simple little experiment has the _potential_ to prove him wrong yet again, and the Believers cannot withstand any such challenges to their faith.
ramset
Thanks Grandma
Quote from: ramset on December 02, 2015, 08:37:14 AM
here is a man showing why the shape Mack utilizes in his ramps can be quite tempting in the possibility department...
got this from Mark Dansies site
http://www.bing.com/videos/search?q=youtube+magnet+rolling+on+narrow+triangle+metal+a+simple+magnet+ramp&view=detail&mid=C282B6872F6A1B508DEBC282B6872F6A1B508DEB&FORM=VIRE1
Actually it's Yet Another video showing simply that magnets are attracted to metal, with Mister Hand first placing the magnet at a location where magnetic potential energy is high and releasing the magnet so it can travel to a place where MPE is low.
Guess what: you can put a weight on a table, then push it off and let it fall to the ground. The weight moves from a position where gravitational potential energy is high to one where it is lower, and work must be done to move it back again to where the energy is high (back onto the table). You get out what you put in, minus losses.
Or hold a magnet a small distance away from a block of iron and release it and watch it jump over and stick to the iron. Big deal! Whoopie!  Make a video and claim that it is "quite tempting"! Because it is exactly the same phenomenon that is demonstrated in that video. Again, you get out what you put in, minus losses.
There is _no_ configuration of ramps, stators, whatever, that will result in putting energy IN to a rotational system like the "Mack Motor" alleged design, and the proper experimental testing that I have been advocating will show this to be true, quite easily. All will only add drag (or in the best case do nothing), and will make the rotor come to a stop faster when its initial starting energy is used up. And that is exactly why none of the Believers will actually do (or rather _report_) the testing -- they are afraid to acknowledge that their entire premise is simply wrong and that their Guru has duped them. But you can bet your bippy that they are each discovering this fact on their own in their own ways, which is why that thread has dropped off the front page and the builders have moved on to other things.
ramset
well
magnets climbing vertically against gravity .. while carrying a spinning paperclip ..does give me pause to contemplate the "what ifs"
and also the fact that Macks ramps are more or less EXACTLY this shape ..
Mack did say "think in three dimensions ' not two ,
gives pause for thought IMO.
Chet
Thanks Grandma
tinman
Quote from: ramset on December 03, 2015, 09:06:47 AM
well
Chet
No,no,no Chet-nothing out of the ordinary happening there.
But the one below will be a little harder for the guru's to dismiss.
How will they explain acceleration of a mass that can actually leave the gate at the end of the run?.
This one starts at a stand still,rolls up hill,and exit's the gate.
https://www.youtube.com/watch?v=gNijcXPcTs0
