A sincere gentleman sharing a magnet motor build .[NDA issues??]
Started by ramset, August 26, 2015, 08:37:49 AM
0 Members and 25 Guests are viewing this topic.
PIH123
Quote from: ramset on October 22, 2015, 01:56:34 AM
I honestly have no idea why he does what he does[ refuses testing or public investigation ]
I find it funny that Brad's very thorough  investigations are happening in a thread where there has never been an investigation of EMJunkies initial claim or anything ??[at least that I am aware]
not even a black box investigation ??
ZERO Zilch NADA ??
I totally agree with that sentiment.
And it is precisely why I would put MadMacks device in the same category.
TK has offered a very reasonable and SIMPLE method for baseline testing, which would take minutes to do.
All replicators have the ability with almost no cost (maybe the price of a piece of string) to do this.
Yet none have (or ever will).
This is the elephant as far as I am concerned.
And I also agree with what you say about Tinman. A good honest experimenter / replicator.
Pete
ramset
A spin down test,  or input over output  is self evident to a true builder .
IT IS NOT SOME HOLY REVELATION... How else could you possibly guage results ??
Thanks Grandma
massive
Has anyone seen the "Energy from the vacuum " part 4 DVD ??????????????
http://www.energyfromthevacuum.com/Disc4HoJo/index.html
DVD is Howard Johnson himself talking and demonstrating his linear motor and magnetic thrust in his house, 2005
none of this is youtube
ramset
massive
I was unaware of any such movie from 2005
here is an unusual statement from your link
Howard Johnson writes:
QUANTUM MECHANICAL MOLECULAR ENERGY
This is stimulation of high molecular energy by shaded pole electron spins that produce powerful parallel spins releasing high energy discharges when they revert to their original anti-parallel spin state.
   This lasts only one to three hundredths of a second and is ten thousand times stronger than the direct magnetic interaction
would be nice to see those vids !!
Chet
Thanks Grandma
sm0ky2
Quote from: massive on October 23, 2015, 03:39:03 PM
Looks like a nice vid, I don't have $30 to give to Tom's empire right now, but it might be worth the watch.
To chet::
H.J. uses a lot of terminology he coined himself. The effect, however, is a real scientific occurrence.
The natural state of a magnetic material, radiates a magnetic field of a given strength.
When two magnets interact, the shape and density of this field changes.
In certain configurations, field density can become greater than the magnetization energy of the material in localized areas.
This can cause a temporary field interaction with an exponentially greater field strength than the combined fields of the two magnets.
the "rest state" of a magnetized material is balanced, in terms of electron interaction. They don't compete with each other for orbital space.
When you distort the field, this balance is no longer possible. Now, two passing electrons are occupying less space. This means the field they create will be more intense.
[xEv/c^2]/(volume) +/- a quantum factor and some variables that don't "really matter" here.
the closer the electrons get to each other, the greater the energies of the interactions.
bottom line is, the more you compress the field (with a factor of the materials properties), the more "magnetism" is produced in the compressed region.
There is a give and take, the shape of the field becomes asymmetrical, and field density is not a linear gradient, there are weak areas, and strong areas.
the strong areas are what H.J. studied. and specifically, the moment of maximum field intensity.
What Howard figured out was that he could use magnets of one type to compress the field of a small piece of a much stronger type of magnet,
and obtain much greater field maximums
for instance, using ceramic ferrite to compress the field of samarium cobalt
Now, when you have fields that are "partially compressed", and you bring a 3rd, moving  magnet into play -
  the changes in field intensities can cause a motive force on the 3rd magnet.
This is most easily demonstrated in Howard Johnson's linear gate, here two opposing fields are placed a distance apart, and a 3rd opposing magnet is introduced.
at each junction along the tracks, the field compresses in one direction, then releases in the other, pushing the roller-magnet along
it is only "linear", because the force is equal on both sides of the round roller balls. the actual force-vector is an arc
https://www.youtube.com/watch?v=o6F9I5OiSTE
