World's first real Free Energy Flashlight - no shaking - no batteries! No Solar
Started by e2matrix, August 29, 2015, 09:01:12 PM
DreamThinkBuild
Hi E2Matrix,
Thanks for the link.
I did some further research and find the company has some pretty interesting acquisitions and technology.
This news page here details some info about the accumulator:
http://www.adgex.com/News/tabid/69/EntryId/2077/NICKEL-CADMIUM-ACCUMULATORS-OF-ADGEX-ENERGY.aspx
NICKEL – CADMIUM ACCUMULATORS OF ADGEX ENERGY
Tuesday, November 25, 2014  RssIcon
Serial Production of globally manufactured electrodes for alkaline accumulators comprise padding from porous perforated net, whereon conductive layer made of nickel and active mass or lamella is applied. Structure features of electrodes are associated with various types of accumulators: starters, tractive, continuous, and short charge, where they are applied.
Adgex Energy designed production technology of electrodes, which consist of volumetric porous nickel (or any other metal) frame instead of perforated net and lamella. The frame is filled with active mass, having good electric contact with terminal (porous nickel frame). Such solution makes production technology of electrodes for alkaline accumulators universal and enables to produce accumulators of various purpose, chemical system, and prime cost at one technological equipment.
ADGEX ENERGY Division successfully tested accumulators NKF-40, completely assembled under our technology. Fully discharged accumulator nkf-40 was charged by 100a for half an hour and demonstrated 14,2V.
You may click the link below to see a video of conducted tests on our YouTube channel:
http://www.youtube.com/watch?v=KLexa698RzI&list=UUWT7oEtJWuNRx6KGX6DekQA
Technical President ADGEX ENERGY Mr Yuri Ignatiev proved that our technology may implement the following:
    Produce electrodes for various types of accumulators, for both tractive and starter.
    Easily re-adjust for any types of systems (nickel-cadmium, nickel-zinc, nickel-iron, nickel-hydrogen, nickel-hydrid).
    Significantly reduce prime cost of accumulators.
    Produce unique high-capacity condensers (nickel-coal), with specifications transcending any existing species of condensers
Researches in the field of powder metallurgy revealed the role of high-dispersed powders in organization of great active surfaces during production of nickel oxide electrodes for alkaline accumulators. Usage of nickel porous frame, obtained by the method of polyurethane foam plating (non-palladic) as a frame for application of high-dispersed nickel powders, in liaison with active mass enabled to increase specific capacity of electrode from 0,35 to 0,55 AH/cm3, that in turn permits augmenting specific power specifications of alkaline accumulators  (Ni-Cd, Ni-Zn, Ni-H, Ni-Tg) by not less than 20-25%.
Another know-how of ADGEX ENERGY is electric charge of porous frame with (+) and (-) active mass, which enabled to sharply raise specific power of alkaline accumulators for up to 150W/kg and expand the field of its application.
Managing Director Mr Victor Uzlov said this is the fifth generation of accumulators of existed technology. Basic advantages of ADGEX ENERGY's accumulators are as follows:
    No risk of short circuit!
    No harm at full discharge!
    Low self-discharging level!
    Service life 15 years and guaranteed not less than 25 000 cycles!
http://www.adgex.com/News/tabid/69/EntryId/2094/LAUNCHING-SERIAL-PRODUCTION-OF-NEW-GENERATION-LAMPS-POWERED-BY-ELECTROMAGNET-ENERGY-OF-ENVIRONMENT.aspx
LAUNCHING SERIAL PRODUCTION OF NEW GENERATION LAMPS, POWERED BY ELECTROMAGNET ENERGY OF ENVIRONMENT
Friday, January 23, 2015  RssIcon
ADGEX ENERGY division proudly announces that at the end of 2014, research activities of reactive electro-magnetic waves and production of special electric generator on their basis were successfully finalized. Relied on the present energy generation method, various devices, capable of restraining the high-speed flow of reactive current into usual hot current, which in turn can be used, for instance, to charge batteries, have been designed. In the nearest future, ADGEX ENERGY is ready to submit international patent application for the invention.
Technical President of ADGEX ENERGY, MR Sergei Ivchenko gives the following explanation to the nature of the present invention:
«As it is widely known, human being lives in the world of electro-magnetic emissions in environment. These are electro-magnetic emissions of space and sun. Great background emission is created by the Earth's magnetic field that possesses power 2,6992139х1024 Watt. Considering the fact, that all power stations of the world together possess power 5x1012 Watt, than significance of the Earth's magnetic field becomes clearly comprehensible. The Earth's atmosphere in all directions is pierced by the flows of electron neutrino. This is natural basis of all electric phenomenon in the Earth's magnetic field. Henceforth, it is perfectly clear, that initial source of atmospheric electricity is currents of electron neutrino sphere, and local currents and dynamic charges of clouds are their derivation. Therefore, lighting strikes are primary natural source of resonance excitation that is called as Schumann resonance. Lightings act as huge transponders, which emit electro-magnet energy on frequencies lower than 100 kHz. They are the reason of excitation of electro-magnetic oscillations in a wide range of electromagnetic frequencies, which come laden with reactive energy. Reactive electro-magnet velocity is greatly in excess of speed of light. Such impulses are also called as currentless or impulse of cold electricity, discovered by the great Serbian scientist Nikola Tesla.  The present phenomena explain availability of steady ultra-low frequency oscillations, which are virtually not faded and have fixed frequencies».
ADGEX ENERGY division developed and successfully tested product line of autonomous household lamps, with capacity from 1 to 5 Watts. It should be mentioned, that tests were conducted in both hemispheres of the Earth. It will be a great present for customers, who get used to be in distant places of the world, where there is no opportunity to plug in to electricity.
Managing Director Mr Victor Uzlov said that in Fevruary 2015, ADGEX schedules to output the first serial batch of autonomous household lamps with capacity of 3 Watts and metal case. Sales are to be carried out via the Company's web site. Pre-orders can be already done today. Thus, you can become the first user of the first world lamp, long time operating without charging. Average price is 90 dollars.
http://www.adgex.com/News/tabid/69/EntryId/2122/THE-WORLDWIDE-SENSATION-ON-THE-25TH-OF-MAY-2015-ADGEX-STARTS-SALES-OF-TORCH-THE-FIRST-IN-THE-WORLD-USING-NEW-PRINCIPLE-OF-SELF-CHARGE.aspx
http://www.adgex.com/News/tabid/69/EntryId/2142/PRESENTATION-AND-OFFICIAL-ELFE-RELEASE.aspx
The patent is Australian so there is pretty much no detail given about anything. :)
http://www.ipaustralia.com.au/applicant/adgex-limited/patents/
Patent AU 2015202321 : METHOD OF CHARGING BATTERIES AND THE CHARGER
http://pericles.ipaustralia.gov.au/ols/auspat/applicationDetails.do?applicationNo=2015202321
The company has acquired some other interesting tech which there isn't much information on.
EXCLUSIVE RIGHTS TO KNOW-HOW
• May 2013, ADGEX has acquired Exclusive rights to "Know How" relating to elevated track
structure known as "UPRAIL". Behind this "Know How" assets, lies some of the most
advanced transport engineering, proven civil construction techniques and optimized
individual structural components.
• December 2013, ADGEX has acquired Exclusive rights to the technology named "New
Generation Combustion Engines" with potential effect of improving power by 25%,
estimated double engine-service life with 30% less fuel consumption.
• December 2013, ADGEX has acquired Exclusive rights to the technology named "Method
of Dynamic Conservation of Mechanisms" with potential effect of minimization of friction
loss and estimated increase in the service life of parts and whole constructions.
• April 2014, ADGEX has acquired Exclusive rights to the technology named "Electric
Engines with Flat Printed Circuit Rotor". Flat construction of engine provides considerably
smaller, thinner and lighter structure of electric driver with low inertial moment.
• April 2014, ADGEX has acquired Exclusive rights to the technology named "Method for
Production of Ultrastrong Matrix of Mavitacetals". Qualitative augmentation of physical,
physical & mechanical and operational features of metals allow increase the next
characteristics: resistance to shock, crack and rust, heat resistance (up to 1100oC), and
tolerance to aggressive environment and abrasion resistance.
• June 2014, ADGEX has acquired Exclusive rights to the technology named "The Method of
Energy Resource Preservation". Application of this technology extends life of mechanisms,
reduces quantity of energy consumption and polluting emissions.
• August 2014, ADGEX has acquired Exclusive rights to the technology named "Concept of
Modular Locomotives". New conception of rapidly and mutually interchangeable operative
modules of the main and supplementary locomotive's equipment with common base.
Modular structure represents non-stationary fast-detachable sections with hulls, where
equipment of common purpose is positioned.
• August 2014, ADGEX has acquired Exclusive rights to the technology named "Free
Renewable Energy". Autonomous power supply sources and alternative methods of
energy generation.
• August, 2014, ADGEX has acquired Exclusive rights to the technology named "Alkaline
Accumulator Based on Nickel-Porous Frame". Production of no-analogue universal highefficient
alkaline accumulators, with high cyclicity and low internal resistance, capable to
restore energy in 5-7 minutes.
• August, 2014, ADGEX has acquired Exclusive rights to the technology named "EC-Gearing
with Ceramic Valve Alloys". Production technology of numerous amount of technical
aggregates on the basis of eccentric-cycloidal gearing.
• October, 2014, ADGEX has acquired Exclusive rights to the technology named "Synthesis
of Functional Material". It enables obtain high-perfect crystals with completely faceted
crystallization front, free from defects and with high transparence grade, quality of which
is the highest of any crystals ever obtained in the world.
• October, 2014, ADGEX has acquired Exclusive rights to the technology named "Drive Control
and Anti Derailment Mechanisms for Transport Systems". This is a technology, consisting
of four elements: differential, Monorail transportation system with autonomous module,
suspension device for aerial lift, module on a pneumocushion.
• October, 2014, ADGEX has acquired Exclusive rights to the technology named "Universal
Walking Mechanisms". It enables to produce walking electromechanical devices and
facilities, capable of being fitted on wheelchairs to overcome staircases and other
obstacles.
• November, 2014 ADGEX has acquired Exclusive rights to the technology named "Technology
of High-Speed Ablative Pyrolysis". Production technology of singular mobile plant, able to
restore any hydrocarbon-containing waste into power energy and high-grade eco-fuel.
• November, 2014 ADGEX has acquired Exclusive rights to the technology named "Vacuum
Integrated Technologies for Information Matrices". This is design-engineering principles of
hardware components of nanoelectronics, relied on autoelectronic (field) emission.
VORTEX HEAT GENERATOR
Construction of vortex heat generator, based on the theory of Viktor Shauberger, explosion
and implosion law, and Tesla turbine has been designed and now it is being tested. Heat
generator is capable of generating of hot water for heating or superheated vapor for private
cottages and residential estates, industrial premises and buildings. Coefficient of efficiency
of such plants is more than 100%. Operating fluid of the generators is water, oil or antifreeze,
which are spun in turbine of centrifuge up to hypersonic speed. At that, cavitation bubbles,
which liberate excess energy, consumed for heating, are formed. The system is closed type.
Turbine spinning is implemented by means of regular electric motor.
TECHNOLOGY OF AUTONOMOUS LIGHTING DEVICES AND LOW POWER SOURCES
Technology of autonomous LED lighting is based on absorption of air electromagnetic shock waves. Absorption is carried out by means of special transponders. LED or low power source are connected to such transponders. Service life of such devices is 5-10 years, unless LED is completely demolished. Capacity of such devices is 0,1 – 100W.
pomodoro
If it works it would be a world first.  Lets wait and see if someone purchases one and lets us know how it works. Meanwhile the list of stuff the company has rights to seems excessise. You know what they say.... jack of many trades but master of none.
RomanEmpire
I've found this video, maybe it could be useful
it is translated from russian
https://www.youtube.com/watch?v=vTJldiHhCq8
There are some more informations about the lamp, Eg. that it uses the "Principle of energy generation told by Sergey Ivchenko" and it produces 3watt "but is much brighter"..
at minute 11:20 the presentation of the lamp
The production seems to start in December 2015
gravityblock
Here's a demonstration of the NiCd super accumulators by Adgex Energy.  Also, check out Adgex's Facebook page.  This is a good source of information.  If Adgex is the real deal, then this has Putin's name written all over it, LOL!
Gravock
