Clem Engine was the real deal, I now know how it works and can prove it!
Started by TommeyLReed, September 18, 2015, 07:46:37 PM
TommeyLReed
Hi All,
This video I did a few years back showing a vacuum created do to the rotational inertia on the clem engine prototype.
https://www.youtube.com/watch?v=D2L_PBGgHZw
Tom
pomodoro
Thanks for the formulas and video links Tommey,  you sure put a hell of a  lot of work into this! Many hours indeed. Very interesting, keep up the great work!
shylo
Hi Tom, Your jets , What is the best angle to surface, you have found?
Is it around 30-35deg. ?
As the speed increases, the angle changes?
Clem used oil, I've found that oil , the faster it moves ,the less power to move it.
Viscousity is the same as resistance?
You spin a flywheel, right?
Can't watch any video's my data's up.
Thanks artv
TommeyLReed
Hi All,
I was wondering if anyone knows of a Richard Clem engine video that was taking when he dove his car around town?
Some interesting read:
Comments to CLEM1.ASC (KeelyNet)
Richard Clem's rotational engine
Although I do not have any direct experience with Clem's device, I would like to comment on the principle of operation, which seems quite simple and straightforward to anyone who has studied the writings of Viktor Schauberger, the Austrian naturalist and inventor.  Indeed Schauberger was working with vortex action in liquids (especially in water) and was finding effects that were at the time, and are still now, unexplainable with the normal principles of physics or thermodynamics.
As far as I understand, the engine made by Clem was built around a cone with spiralling channels cut into it and when a liquid, in that particular case vegetable oil, got pressed through the channels, they caused the cone to turn. At a certain point the flow of the liquid and the turning of the cone became self-sustaining, up to the point of putting out a good and heavy (350 HP for a 200 pound engine) power output.
As I said, this is not surprising if one is familiar with the work of Schauberger. In the USA, there is one person I know of who has researched Viktor Schauberger's work in depth and who is trying to disseminate the vortex technology that grew out of Schauberger's work, through a publication called Energy Unlimited and a newsletter ("Causes"). His name is Walter Baumgartner but unfortunately I do not have contact details.  To return to the Clem engine, the principle of this machine is based on the fact that vortices under certain circumstances are self-accelerating and may be used to do actual work.
One example of this in nature is the tornado, which may reach very high rotational energies without apparent input from the outside.
Schauberger used this principle before the Second World War, to run a small turbine for electric energy production that is said to have had an output of approximately nine times that a conventional turbine would have had with the same amount of water and the same altitude differential. He patented his turbine and the patent is described in a separate article of mine.
It is not known for certain what this effect is based on. From my view there are two possibilities:
1) A vortex "absorbs" ambient heat and utilizes the energy contained in it to augment its own motion. As heat is in fact molecular or atomic motion (absolute zero being the absence of any motion of this kind), a vortex could conceivably be able to direct that motion into one direction, thus ending up with
a) decreased environmental temperature and
b) increased motion.
Both factors seem to hold true for vortices.
2) The second possibility is that the vortex motion, being the most congenial motion to the aether or space background, is a means of tapping the inherent energy in space, also variously called zero-point energy, space energy or gravity field energy. A vortex, especially fast-turning and especially in dense material, may be "assisted" in its motion by a vortex forming in the space background or aether, that will eventually contribute energy to the vortex in the fluid.
These two explanations are not mutually exclusive and both mechanisms may be at work. They are at this time speculative attempts to explain properties of vortices. Although the explanations are speculative, the properties of vortices as such are not. They have been observed and measured and are shown to us daily by nature.
What Schauberger (and now Clem) have done is they have found a way to harness a phenomenon that has been given little attention by the scientific community.
The implications of this for energy production are enormous as can be readily seen reading the file CLEM1.ASC on KeelyNet. Josef Hasslberger
Rome, Italy
17/5/1995
Originally posted on December 26, 1992 - CLEM1.ASC A few months back, we got a call from a friend who had heard of this incredible motor that was said to run itself and generate excess useable power. The details were unclear at the time and our friend gathered more details and we met for lunch to discuss what he had found out. This file with diagram is listed on KeelyNet as CLEM2.ZIP. As we understand it, inventor Richard Clem died of a heart attack soon after the deal was signed with the coal company. His workshop was raided by law enforcement officials and all his notes and drawings were removed. The story as I was told by our unnamed friend : A local man (Dallas) developed a closed system engine that was purported to generate 350 HP and run itself. The engine weighed about 200 pounds and ran on cooking oil at temperatures of 300 F. It consisted of a cone mounted on a horizontal axis. The shaft which supported the cone was hollow and the cone had spiralling channels cut into it. These spiralling pathways wound around the cone terminating at the cone base in the form of nozzles (rimjets). When fluid was pumped into the hollow shaft at pressures ranging from 300-500 PSI (pounds per square inch), it moved into the closed spiralling channels of the cone and exited from the nozzles. This action caused the cone to spin.  As the velocity of the fluid increased, so did the rotational speed of the cone. As the speed continued to increase, the fluid heated up, requiring a heat exchange and filtering process. At a certain velocity, the rotating cone became independent of the drive system and began to operate of itself. The engine ran at speeds of 1800 to 2300 RPM. Immediately after the inventor had the heart attack and the papers were removed, the son of the inventor took the only working model of the machine to a farm near Dallas. There it was buried under 10 feet of concrete and has been running at that depth for several years. In later conversations, our contact says the engine had been tested by Bendix Corporation. The test involved attaching the engine to a dynamometer to measure the amount of horsepower generated by the engine in its self-running mode. It generated a consistent 350 HP for 9 consecutive days which astounded the engineers at Bendix. They concluded the only source of energy which could generate this much power in a CLOSED SYSTEM over an extended period must be of an atomic nature. Construction of the engine was from off the shelf components except for the hollow shaft and the custom cone with the enclosed spiral channels. Richard Clem worked with heavy machinery for the city of Dallas and had noticed that certain kinds of high pressure pumps continued to run for short periods after the power was removed. His curiosity into this phenomenon led to the development of the Clem Engine.
TommeyLReed
More:
The Clem Over-Unity Motor The following is from a newspaper clipping that has no name or date. In 1972, Richard Clem announced the invention of a way to operate automobile engines on cooking oil. He's still making that claim today, even though his first prototype motor fell apart and he had been "strung along" by at least 15 companies before he found financial backing. Clem, 48, a heavy equipment operator for the city of Dallas and part-time inventor, says if the automobile industry adopts his invention, motorists could change the eight gallons of vegetable oil only every 150,000 miles and never buy any gas. Clem said he uses vegetable oil because his motor runs at 300 degrees - a temperature where water has boiled away and conventional motor oil breaks down. Though he won't divulge many details of the engine, a 12-volt battery apparently is the only other source of power. When Clem finished his first vegetable oil engine in 1972, he mapped a 600- mile test trip to El Paso for the first engine model he had financed through his earnings.  But he only made it as far as Abilene before the 'shafts and everything bent in it.' He blamed the failure on poor construction, too small a shaft and the use of chains instead of gears. Undaunted, he decided to try again, but said, 'I needed money to build this thing better.' Neither the automobile industry nor the 15 other companies he wrote - some as far away as Taiwan - were interested in financing a prototype and then manufacturing it. Then last year, he said, a large coal company offered to back him. Clem refused to disclose the name of his benefactor, but did say the coal company had signed contracts to sell the engines to power companies for use in pulling turbines. Clem said he expects to finish work on the motor by the end of this year. (1972)
Vanguard Note..
The above article was reported as being generated from Flower Mound, Texas (northwest of Dallas and slightly beyond Carrollton). I called the only Clem listed in the book as of 11/20/92 and they knew of no other Clem in that area, nor did they know of any Richard Clem or his family. Two separate visits to the patent section of the Dallas Library have not yielded any patents by a Richard Clem involving any type of engine. We are still pursuing for more details. As of 12/26/92, I drew up a .GIF file called CLEM1.GIF that is bundled with this file under the name CLEM2.ZIP. It gives a better understanding of how the machine was constructed, at least as it was described to us.
For those who study such matters, one immediately sees the tie-ins with Boundary Layer Drag principles as evinced in much of Tesla's work as well as Victor Schaubergers Impansion and Implosion discoveries.  We have noted something odd about spinning masses in that at specific velocities, strange things occur. The velocities at which phenomena occur are dependent on the resonant frequencies of the mass as an aggregate, exactly as Keely said. The Clem system was said to be built with off-the-shelf components. The most complicated piece of the entire machine was the cone. And based on Boundary layer drag, it would seem that the cone was unnecessary.  The question with the Clem device is 'Does the extended surface area of the cone add to the additional velocity of the cone, yielding greater pressures through centrifugal force or would flat plates as in the TESLA turbine be sufficient to generate the same effect?' We continue to look for more information on this device and appreciate your comments or supporting material.
Update as of May 1996
A company called Creative Sciences is selling plans ($60) for what they claim is a machine that generates 1500hp and runs by itself. They call this a CEACU and claim it was released by a 70 year old retired scientist.
The truth of the matter is it was designed and built by the late Richard Clem of Flower Mound, Texas as documented by this paper. It is wonderful that someone has taken this information and done something with it (or so claimed) and we will have more details later if you might like to build one. However, be aware a few years ago, some of our Roundtable group chipped in for about $150 worth of 'plans' from Creative Sciences.  The plans were bogus and were not free energy unless you are simple enough to think compressed air (as used in some of Dennis Lees 'demonstrations') is free energy. In the last part of June 2001, Rick Harrison, president of Creative Sciences sent an email to KeelyNet saying he was prepared to sue if we did not stop 'bad-mouthing' his company.  The website is http://www.fuellesspower.com and I told him go ahead, since I and many others would love to see them prove their overunity claims in court. Since then he has not responded back and the website is not responding, so I think they are changing their claims.  We also have several emails from others who say Creative ripped them off and one from Brazil saying its been 60 days after he sent about $115.00 and received nothing. With regard to differences between the CEACU design and Clem the CEACU does not require the cone, but instead uses a thick disk with nozzles on the outer edge. A hollow shaft feeds water into this disk at a high velocity.  As the water exits from the nozzles, the disk spins giving an ever higher velocity. A 3200 psi air tank is used to get the disk spinning to 1000 rpm when it is claimed to begin to run on its own. There are other ways to achieve this velocity beyond 3200 psi as you can well imagine. If you write them, please let them know that Richard Clem is the true inventor (as I will). Thanks!...
Jerry W. Decker  Sysop / KeelyNet
