PLEASE ALERT THE WORLD ABOUT THIS HIDDEN UFO TECHNOLOGY IN BIBLE
Started by that_prophet, October 11, 2015, 08:11:48 AM
that_prophet
This is based on the mechanical ability of one rotation of a 100cm circumference pulley giving you a belt, strap, rope or even tied length of string, in a pinch, giving you 100cm length of moving belt. Then when you run this length of belt through one to ten of one centimeter circumference pulleys, you would get between 100 – 1000 rotations = cycles of AC electricity, if you attached AC generators to these mini-pulleys. That is one spark of DC electricity, could give you 100 to 1000 cycles of AC electricity. HOW COULD YOU NOT GAIN MORE ELECTRICITY THAN YOU PUT IN. These 100-1000 rotations of your AC generator are not hard to rotate, because they are just winding up massive voltage, and only need to generate one spark of current, as a DC motor only takes one spark of DC electricity, to turn over your motor the once. Resistance is created by voltage times current, and since we need so little current, (only one spark) there would be practically zero resistance on these one to ten mini-pulleys. This massive voltage that you are winding up not only is more than great enough to push over your DC motor once, but has lots more, to help you drive whatever motors that you want to plug into your AC or DC motors output.
that_prophet
This gets around your thermodynamic law of power out always being less  than your power in, by switching to the drastic geometrical gain of rotations from a large 100cm circumference pulley, to small one cm circumference = 100 multiplication factor of rotations.(which is how AC electricity is made) This is based on the mechanical ability of one rotation of a 100cm circumference pulley giving you a belt, strap, rope or even tied length of string, in a pinch, giving you 100cm length of moving belt. Then when you run this length of belt through one to ten of one centimeter circumference pulleys, you would get between 100 – 1000 rotations = cycles of AC electricity, if you attached AC generators to these mini-pulleys. That is one spark of DC electricity, could give you 100 to 1000 cycles of AC electricity. HOW COULD YOU NOT GAIN MORE ELECTRICITY THAN YOU PUT IN. These 100-1000 rotations of your AC generator are not hard to rotate, because they are just winding up massive voltage, and only need to generate one spark of current, as a DC motor only takes one spark of DC electricity, to turn over your motor the once. This massive voltage that you are winding up not only is more than great enough to push over your DC motor once, but has lots more, to help you drive whatever motors that you want to plug into your AC or DC motors output.
that_prophet
This gets around your power in being greater than your power out, by switching to the drastic geometrical gain of rotations from a large 100cm circumference pulley, to small one cm circumference = 100 multiplication factor of rotations.(which is how AC electricity is made) This is based on the mechanical ability of one rotation of a 100cm circumference pulley giving you a belt, strap, rope or even tied length of string, in a pinch, giving you 100cm length of moving belt. Then when you run this length of belt through one to ten of one centimeter circumference pulleys, you would get between 100 – 1000 rotations = cycles of AC electricity, if you attached AC generators to these mini-pulleys. That is one spark of DC electricity, could give you 100 to 1000 cycles of AC electricity. HOW COULD YOU NOT GAIN MORE ELECTRICITY THAN YOU PUT IN. These 100-1000 rotations of your AC generator are not hard to rotate, because they are just winding up massive voltage, and only need to generate one spark of current, as a DC motor only takes one spark of DC electricity, to turn over your motor the once. This massive voltage that you are winding up not only is more than great enough to push over your DC motor once, but has lots more, to help you drive whatever motors that you want to plug into your AC or DC motors output.
that_prophet
I was thinking that this is so simplistic, that I was hoping that all of the evil spirits in this vast universe, could not find a way to poke holes in it. But I guess that those enemy forces still have a key word, torque, that strikes doubt in our unbelieving souls. How can I put this any clearer, these AC generators are just being used to wind up massive voltage. All of these many AC generators together, doing their massive rotating, only need to generate one single spark of current, (practically none). That is because the input for your DC drive motor, connected to the large 1000cm circumference pulley, only needs to be a single spark of current. That is because you only need to rotate this large pulley once, and it will give you a return of 1000cm of moving belt.
Then, when you run this 1000cm of moving belt through one to ten mini-pulleys, having only one centimetre circumference, this will translate into 1000 to 10 000 cycles of AC electricity. There is no more discussion needed, with only one spark of DC input, you are using the mechanical abilities of pulleys, to gain a return of 1000 to 10 000 units, (sparks) of AC electricity. This shows a clear multiplication of electricity, which means that you do not have to pay for it to be generated by fossil fuels, or the heat off nuclear fission. In essence, you are using this technology to multiply already generated electricity, there by gaining free energy.
that_prophet
free energy is done using pulleys
http://free-energy.yolasite.com/
It uses the simplicity of it not taking 100 times as much force turning a 100cm circumference pulley, as it does turning a 1cm circumference pulley, yet you get 100 times more LENGTH OF MOVING BELT to work with. If you run the 100cm of belt by any # of 1cm circumference pulleys, you would gain the # of mini-pulleys times the multiple of 100 units of AC electricity.
THAT IS WHY I CALL THIS THE GEM OF AC ELECTRICITY MULTIPLIERS
GEM =(Geometrical Electricity Multiplier)
