Thanks to ALL for your help!!
All of your Free Energy dreams are about to come true!
Started by Bruce_TPU, October 17, 2015, 10:36:43 PM
Bruce_TPU
Quote from: Terbo on October 18, 2015, 11:46:52 AM
What happens in 10 days?
Keisha states to his ambassadors that in ten days from yesterday he will open all patents to the public.
I have yet to find any demonstration of output other than hyperbole.
I found one experiment like mini earth batteries that produced 1.5 volts each.   He stated in the video that the battery will last 30 years.
Another video shows decent voltage but it is open circuit with no load. Unfortunately 8 hours later the open voltage had dropped considerably.
I DO like the concept of nano covered copper wire for exploring and experimenting and the process seems fairly simple.
He did pass out boxes with devices in them but it would be nice to see a unit working.   And he is selling them but not yet delivering units. This too concerns me.
Cheers,
Bruce
Bruce_TPU
Quote from: Bruce_TPU on October 18, 2015, 03:21:00 PM
Cheers,
Bruce
This is the method that they use to make their battery "beads"....
http://www.slideshare.net/pacodelamar52/battery-beads-making-bateras-tipo-perla-de-tecnologa-keshe
Cheers,
Bruce
ramset
Bruce
I would love to hear from somebody that has played with some of these beads and things.
thx for starting this topic, will be nice to see where this goes
Chet
Thanks Grandma
Tito L. Oracion
Cheers,
Bruce
nice shot bruce. that is a good info. i'll copy it. ;)
just a wild thinking :
What if we powderised the copper and nnano coat it?  what do you think? :D [size=78%] [/size]
