Thanks to ALL for your help!!
75 watt free energy from air schematic
Started by magnetman12003, October 20, 2015, 07:06:17 PM
magnetman12003
The below link will show my schematic diagram of a setup that can possibly produce 150 volts at 500 milliamps.
That's 75 watts of power if the antenna is large/long and high with an excellent ground. Location near a radiant energy source very desirable also.
I decided to OPEN SOURCE this info for anyone deciding to build it.  Al parts are inexpensive and available on
Ebay. I am presently constructing it.
The C1 to C8 caps are 0.22uf Mylar.  The C9 to C 16 caps are electrolytic 33uf.  Working voltage of all caps must be over 150 volts.  The small signal diodes are rated at 150 volts 500 milliamps.  All diodes are Fairchild 1N458A
https://www.youtube.com/watch?v=_2GPfFT3u7U
forest
Berto3
He, magnetman. If you first construct the 'antenna energy harvester' and after that you come with volts and miliamps. Would that be a better order?
magnetman12003
Quote from: Berto3 on October 21, 2015, 01:45:19 PM
From what I have been reading a huge polished aluminum plate suspended by something like elastic cords inside the attic would make an excellent antenna. Could be rotated for best results.  However as per anything metal raised hi enough its subject to lightning strikes in a storm???
I live close to hi tension where radiant energy is abundant.
Tito L. Oracion
