JB Zero Force Motor - anyone building?
Started by Jimboot, November 03, 2015, 09:53:20 PM
synchro1
@Tinman,
Would there be any likelihood that you could build and test "Skycollection's" induction coil alternator to determine with certainty if the bifilar output coils actually multiply power or not?
tinman
Quote from: Atommix93rdAtom1 on November 09, 2015, 05:37:28 PM
The basic truth is simple ! Pressure of some kind needs to accumulate ! A delay negative or positive grows pressure and the energy for the gain is always from the spin of an electron which is at 5.5 million mph ! The energy of this is emitted from its event horizon and its continuity is its unified quantum state of entanglement with all other electrons in the universe !
Just play about with no formula for a energy gain is like looking for a needle in a galaxy ! The square of the charge is related to the square of the charged proton spinning in the nuclei closest to the free electron field. The charge of the protons is what keeps the quantum state of the free electrons active ! When making your so called Lenz coil you need to make sure its overall event horizon is a scaled up equation of the electrons you intend to feed off but to do that the harmonic of the feed out put electrons must be set up so it can migrate as a 5th note of the scale of the electron field! This will require that the gauge of the coil is off the correct threshold for this event to occur !
The only other option is to set up a negative charge in the coil and feed from the electrons in the ambient ! Many people make these generators work by chance ! But there is no real standard for it beyond the one I have now ! given.
See how the chart provided follows the chart that mile high has given ! All reactions are harmonic response and if you don't start to learn that you will forever be in the dark. I can levitate that Lenz coil and make it power a car a home anything you want !
So now you have the correct speed for the vector of the free electron in your coil and its a imperial number as all imperial numbers are harmonic ! If you keep on with this idea that what you read from some so called academic who has no idea of the quantum state for an electron you got no chance ! Any refusal to except these simple rules will result in events that will always have the wrong formulas to scale up the effect !
DO YOU FINALY SEE THE LIGHT ???????
QuoteDO YOU FINALY SEE THE LIGHT ???????
Yes-->you have been drinking too much.
tinman
Quote from: synchro1 on November 09, 2015, 04:51:04 PM
@Tinman,
You will have to point me in the direction off these induction coils,and what alternator setup you are refering to.
tinman
MOT secondaries make for great air core coils.
Much better than the Zero force motor setup.
https://www.youtube.com/watch?v=flU687Vg0iM
