JB Zero Force Motor - anyone building?
Started by Jimboot, November 03, 2015, 09:53:20 PM
synchro1
Quote from: skycollection on November 11, 2015, 08:47:30 PM
With this experiment i will show you that is not "a trick" This video is very clear ...! is just inductance, is the inductive coupling effect...!
https://www.youtube.com/watch?v=A3NioI-m5EM
saludos from mexico...!
Skycollection tested the inductance oscillator with one, then five bulbs and timed the capacitor discharge. The voltage divided between the five bulbs, but the amperage remained unchanged. This implies that the number of possible inductance coil bulbs should be directly proportional to voltage, and that the amperage would remain constant regardless. A very efficient way to magnify power!
This is an overunity power plant.
synchro1
This is a voltage quadrupler circuit:
The inclusion of this simple circuit would allow Skycollection to increase the number of coil bulbs to twenty with equal luminosity!
tinman
Quote from: Atommix93rdAtom1 on November 12, 2015, 12:26:00 AM
Miles high come back to reality please ! lets add the quantum mechanics of it negative potential is an applied force just because its not in your box of experience its in mine which is out side your box of limitations. Also I did say best effect with a flowing current did I not ? Its space time equilibrium of additional force as the electrons will need to be re ordered along the wave ! You wont see that effect on the OS because its an increase in tension in the line of force ! Its like a wave made with a string or one made with metal same note same frequency different amount of force .... So !! Again please think out side the box please sir !!! SEARIOUSLY ONE WONDERS HOW HIGH YOU REALY DO GET ?
What lets all do it the MIT way hahahaha a bunch of beginners ! They are hardly quantum mechanics are they hahahah
Tritium is the mass of a static construct is it not ??? Did I say the word static ? no you did ! I SAID NEGITIVE ELECTRONS ..... So what's the connection ? How do you add 10 000 % more electrons in the coil with out static ? You have to re order the electrons in fact any order is better than chaos of a bunch of free electrons beforee the current hits !
I did say the stack of coils did I not AND IN THE ARANGEMENT WOULD NOT THE STATIC RISE UP AND DOWN LIKE A WAVE ????? NO ? YES IT WILL !
So than what ?????? remove the charge from the static as the current is in play and what happens ? negative electrons take the place of the tritium .... Never underestimate me sir ! But that is not the full treatment is it ! no thats just around an extra 20 % more mass in the field ! I did say 10 000 % more electrons did I not sir ??? Now you can not do that only I CAN DO THAT SON ....
And than the harmonics !!!! I remember we had a conservation about these before and you still don't understand them ! A piano is also a free energy machine if tuned right ......... hahahahah
So the coils need an up grade for the same price !!! Oh and finally the electron propagation to pick up the surge of the new peak in current ......... Well than !!!! lucky me !!!! Carrie on !!!! Go back to MIT GIVE THEM A COIL AND ASK THE TO FLY IT WITH no generator ! For that you need to be in the earth science team .... Now is tin man going to do the test or is your influence on him by remote control ?
Tesla did well with this effect !!!! But that was a very long time ago.... Nice leds any chance of boiling some water ? no !
What test is that Haha?
Quote from: MorePowerEgor on November 13, 2015, 06:05:06 AM
This looks like it zero force!
https://youtu.be/k3GuD-Q4hts
Oh come on. Ask yourself why the motor has to be positioned on the edge of the table, with part of it hanging over, and why that hanging over part "just happens" to be one of the rotor support columns. And the convenient bit of tape or paper hanging down, blocking the view just under the column.
There is probably a drive belt running up through the column from an ordinary electric motor under the table.
