kEhYo77
Over Goat
Quote from: gotoluc on January 07, 2016, 03:04:25 PM
Hi everyone,
I would need help to find a simple software that I could print a circle of up to 6 inches (15cm) in diameter on white paper. It needs to be pie shape in black for my optical reflector switch off times. It's very simple, if my motor rotor has 8 poles (on times) then the circle would have 8 black pie and 8 white pies equally spaced in the circle. That's all I need but I can't seem to find anything.
So please help my out if you know of something or have some time to look.
Thank you for your help
Luc
try this:
https://imgflip.com/piemaker
ALVARO_CS
Hi everyone,
Luc
Hello Luc
I may do it in a graphic vectorial program I use professionally an send it to you as a JPG with high resolution, in various sizes or number of divisions you´ll like. Just PM and I´ll send it to you asap
Cheers
Alvaro
PS: as well as any other graphic design you may need of course
ALVARO_CS
Ok here you have it in attached pdf
this will work as a 50% duty cycle, if you need other % just say so
cheers
Alvaro
gotoluc
Quote from: kEhYo77 on January 07, 2016, 04:08:23 PM
Inkscape is a free vector drawing software, Luc.
Thanks, I'll have a look but if it's not obvious how to do it within the first minute I'll pass on it.
Quote from: Over Goat on January 07, 2016, 09:43:18 PM
try this:
I've already tried that one and this one is easier:  https://www.meta-chart.com/pie
Quote from: ALVARO_CS on January 08, 2016, 10:10:35 AM
cheers
Alvaro
Thanks Alvaro, that is very kind of you and the resolution is excellent.
I will let you know if I need any other patterns by PM.
Thanks for your help guys
Luc
