Inductive Kickback
Started by citfta, November 20, 2015, 07:13:17 AM
Magluvin
Ok, the bifi measures 15.7nf between turns but the cap needed for the normal coil is 4.3nf and the resonant freq foir each comes out to 12.37khz and 12.88khz for each. As close as I can get for now with the bunch of little caps I have on hand. It was just a small disk cap for the 4.3nf to get the freq that close. So Im expecting there to be similar results with the kicker circuit like Tk says. But I got tied up into some things with getting the 2 coils to be a similar as possible with at least the resonant freq with the right cp on the normal coil, so didnt get to doing that yet.
This was just energizing the test coils directly with everything being even simpler, and they both look very similar in the 1st 2 scope shots with .5v input and the bifi tends to be a bit higher amplitude. The normal coil shot is a very uniform trumpet ring down, but the bifi has a bit of a swing to it and the second down stroke of the wave seems to be clipped earlier than the first swing down. Now when i go to 5v input, things change dramatically as seen in the second set of shots below. The normal coil with the disk cap shot seems to show lots of issues, yet the bifi seems to be that same shape as the first shot and a lot higher p-p than the normal coil.  The cap is 500v. Cant see that as the issue for the bad performance of the normal coil as I have a few of those caps and they all perform the same in the circuit.. I did it over again and again. The higher the input, the worse the normal coil acted in comparison to the bifi. Could the windings insulation be breaking down?  If so, Id think possibly if there were sparking between windings that there might be noise.  Will have to go over it all again tomorrow.
Planned to do a lot more than this tonight, but Im beat now. I have to see what is the problem or reasoning for these results of what should be simple things.  Tomorrow Ill have time to do a vid demonstrating the use of the switch flicking and see what might be going on with this setup. The switch flick is still working well this evening.   The kicker coil and the diode are off the board and out of the circuit. so its not anything else affecting the circuit. Even reversed the dpdt switch around the other way and the same results. Doesnt make sense. .5v in pretty close results. 5v in, pretty crappy results. The only thing that changed was the voltage in.  Like the diode cant be breaking down, the voltage across the coil never gets as high as the bifi shot, of which it should cause the same issue if the diode were bad.
Mags
Magluvin
Quote from: Erfinder on March 07, 2018, 01:59:12 AM
Mags,
If I may make a suggestion, go back to your original experiment.....  Input from others is well....input from others....  you were onto it, I wanted to comment but stayed in my place....  allowing you to do your thing without interference...  don't let anyone take your off your path.
Thanks.  ;)
sm0ky2
tinman
Under fairly controlled conditions,i compared a bifilar coil against a mono coil.
As i first expected,i found no difference between the two. In fact,the mono performed a little better in this case.
https://www.youtube.com/watch?v=lgTmKrLCWI4
minoly
Excellent demo on how NOT to see the effect... people should pay close attention as Edison found thousands of ways NOT to make a lightbulb...
