Evaporation Driven Self-Sustaining System
Started by gravityblock, December 01, 2015, 01:28:33 PM
gravityblock
Quote from: Nink on December 01, 2015, 09:22:04 PM
As I originally stated the energy to get the water to the top of the container is 10 x actual energy created.  You have a water wheel and nothing more.
I disagree with you on this.  The evaporated water from the moisture mill and the moisture in the surrounding air can be recycled by collecting condensation with a WarkaWater Tower that is above the moisture mill in order to refill the water reservoir.  In addition to this, rain water can be collected.  This will run 24/7 without any issues, even in the desert, and can be made self-sustaining if done properly.
Gravock
gravityblock
I would also like to add that their is more to this than just a simple mass imbalance of the wheel.  As the spores absorb the humidity on one side of the wheel, it not only causes the spores to become heavier, it also increases the moment arm of the strips as they expand and straighten out, which increases the torque.  On the lighter and dryer side of the wheel, the moment arm of the strips will decrease as they contract and curl back up while losing their moisture content.  Mass imbalance + longer moment arms for the heavier strips than the moment arms of the lighter strips + the WarkaWater Tower = a self-sustained system based on clean and renewable energy.
Gravock
gravityblock
According to Sahin, an associate professor of biological sciences and physics at Columbia University, "Water evaporation is the largest power source in nature".  Sahin also said the strips could be seen with the naked eye expanding and contracting when he was inhaling and exhaling.  "If this technology is developed fully, it has a very promising endgame", says Sahin
Reference: Getting a charge from changes in humidity
Gravock
gravityblock
Spores are one of the toughest forms of life known and are extremely resistant.  They can survive sub-zero temperatures and boiling water for 5 minutes.  DNA binding proteins saturate the spores and protects them from heat, radiation, and chemicals.
References: Bacterial spores ashraf and Bacterial spore - Wiki
Gravock
gravityblock
Breathe Right Nasal Strips could be used to deposit the spores onto.  These strips have an extra "spring-like" band and is 50% stronger than the original.
Gravock
