Thanks to ALL for your help!!
Deep Water Nitro Piston Generator
Started by william_mills, December 24, 2015, 11:09:33 AM
Reiyuki
Attached is another way to handle it, by sealing an entire chamber and having an object float up/down with a change in buoyancy.  Attach magnets to the object and run a series of coils all along the tube.
It's an interesting thought, because it takes a small,fixed amount of energy to change the density of the system, but the pipe can extend to any length.   Parametric variatio; in this case, changing the 'buoyancy' parameter would result in an overunity potential if the tube was long enough.
sm0ky2
ok so, the unit sinks to the bottom of the ocean, nitrogen is compressed, piston moved in, and locks.
when the pressure gets high enough in the storage tank, nitrogen moves through the high pressure valve
into the hydraulic cylinder, which controls buoyancy.
unit floats to the top, where the nitrogen can be transferred to an energy storage tank above.
the hydraulic cylinder returns to its initial (non-buoyant) state when pressure is relieved.
william_mills
ACTUALLY, I DON'T KNOW WHY SOME GIFs WILL ANIMATE AND OTHERS WON'T...........AND I ALSO DON'T KNOW HOW TO ERASE A POST
To see the animated version of this image, here is a link:
https://plus.google.com/108272637213976563154/photos/photo/6239946654758977746?pid=6239946654758977746&oid=108272637213976563154
This is just the rough draft......better version coming soon!
william_mills
Quote from: william_mills on December 24, 2015, 11:09:33 AM
An Engineering Research Scientist told me this would work, and then refused to speak with me any more about it for fear of being assassinated....lol! It uses the pressure from extreme ocean depth to compress nitrogen filled pistons that are on a conveyor belt type system with ballasts that neutralize the intense weight of the system and also power the rotation of the belt.
Kinda hypothetical at this point, but take a look at my designs!!!!
The second picture is not being animated on this site.....here is a link to see the animated image:
https://plus.google.com/u/0/108272637213976563154/posts/JFq8EtwG5D5?pid=6195383243091835250&oid=108272637213976563154
william_mills
