Perpetual Mobile with compliance of the law of conservation of energy
Started by abv, February 01, 2016, 09:45:18 AM
abv
Also, using same concept could use a ferromagnetic material into constant magnet field.
The idea is very simple and mostly the same.
A ferromagnetic material has a closed thermodynamic system inside with efficiency 100%. This system could heat ferromagnetic material higher than Curie point temperature and also cools it, using energy from the heat. The work of ferromagnetic material info magnetic field is an extra energy.
images:
https://somephysicsideas.files.wordpress.com/2016/01/magent_diagram1.png?w=398&h=113
https://somephysicsideas.files.wordpress.com/2016/01/magent_diagram2.png?w=398&h=110
sm0ky2
Quote from: abv on February 04, 2016, 09:29:12 AM
I think the work against the air pressure should be neglected as kind of friction. As was described the gas expansion and compression processes are equal on same altitude and the closed system has efficiency 100%.
Same for different altitudes. Yes, the pressure of air drops proportionally altitude. But the balloon still goes up in case where buoyancy force more then gravity force. On certain altitude starts gas compression process into balloon using energy from expansion process. On the end of the process the balloon will have a bigger volume than the ballon was initially on the ground. However, the buoyancy force won't enough to hold the load on certain altitude and balloon will loose altitude. On lower altitude the air pressure is bigger than on high altitude. Therefore the current air pressure will compress the balloon. When the ballon will return back to the ground the volume of the ballon will be same when it was on initial stage.
the original premise was that the temperature remains constant. therefore, the change in pressure and volume is proportional.
the forces inside and outside of the balloon, are inversely proportional along the altitude scale. changes in pressure on the way down are the opposite of the way up.
What is buoyancy?
It is the difference in pressure, caused by gravity.
Buoyancy is what makes atmospheric pressure.
gravity is more intense at the ground level, which increases the density of the air.
its the same as water pressure with depth. Though the magnitude of the forces is much less, because of the differences in density.
To make buoyant, is to cause a potential in pressure.
Pressure will always try to balance itself out. greater pressure moving to areas of lower pressure.
To move pressure opposite of this flow, is to do "work".
We haven't even begun to look at changes in temperature affecting the contents of the balloon as you rise into the cold sky
That in itself will drain heat energy from the gasses within.
abv
Quote from: sm0ky2 on February 04, 2016, 10:28:17 AM
What is buoyancy?
Thanks a lot for detailed explanations.
The first closed system is open, because need to count work against air pressure.
I calculated air pressure work for different altitude and it has same value for potential energy of load.
For example
Using this equation for air pressure P=Po*exp(-mu*g*h/RT).
T=293K,R=8.31, g=9.81, mu=0.029, Po=101325, h=1
The dP=11.8383071 PaB
Balloon's volume to raise load 1kg is 0.897585495 m^3
Balloon's volume where buoyancy force = gravity force is 0.067020711 m^3
Using equation dW=dPdV
The work difference against air pressure for altitude difference 1m is
dW=11.8383071*0.830564784=9.83248098J
The potential energy for load 1kg on altitude 1m is
PE=mgh=1*9.81*1=9.81J
Number 9.83248098J close to 9.81J.
I agree, this won't work.
sm0ky2
Quote from: abv on February 05, 2016, 05:18:31 PM
For example
Excellent!!
Now, you can see that the Buoyant Effect - is a function of Gravity !!!
abv
What about this perpetual mobile?
Here should not be count work against air pressure:)
Quote from: abv on February 04, 2016, 09:45:05 AM
Also, using same concept could use a ferromagnetic material into constant magnetic field.
images:
