To be deleted
Started by nul-points, February 02, 2016, 07:23:16 AM
nul-points
thanks for the update, Itsu
average readings (apart from their lower values) still suggest that our circuits are different (ie. your Isupply and Iin are similar, whereas my values show that Ifb as the difference between Isupply and Iin)
ok, so it doesn't look like the missing energy is being radiated significantly
yes, i use the same method for 'NO feedback' tests
np
itsu
NP,
Hmmm,  i would of thought that you would be pleased with my average results as according to me they present
exactly what you were saying (or do i understand you wrong?).
My average values are:
Isupply = 4.07mA,
Iin        = 4.74mA,
Ifb       = 0.80mA
so indeed like you say, "Ifb as the difference between Isupply and Iin"  well, almost.
Itsu
nul-points
hi Itsu
ah ok, i must have seen that the feedback current RMS value looked like the previous table (approx 2mA) where the math wasn't identified (just labelled as current(mA) and thought that value hadn't changed - my apologies!
yes, those values are a closer fit to the pattern of the circuit behaviour
thanks
np
nul-points
QUESTION2: Do the capacitor supply draw-down tests support the general comparison seen on this circuit when using another method (eg. scope math)?
ANSWER: Yes they do...
the 1F (nominal) supply capacitor was identified as having an actual capacitance of 1.111F, using the draw-down time for a 681 ohm resistor (and then using online calculation)
the start and end values for charge on the 1.111F cap for the tests was as follows:-
4.0V  4.444Coulombs
3.4V  3.777Coulombs
The total value of charge transferred was:
  (4.444 - 3.777) = 0.667Coulombs = 667mCoulombs
runtime for circuit WITHOUT FEEDBACK: 68.4s
667mC => 667mAs / 68.4s = an average Isupply of 9.75 mA for 68.4s
runtime for circuit WITH FEEDBACK: 90s
667mC => 667mAs / 90s = an average Isupply of 7.4mA for 90s
the CSR traces show that charge transferred from the supply is comparable for both cases:
WITH FEEDBACK: positive pulse (14.6mA for 9.6us) = 137.24uC
WITHOUT FEEDBACK: positive pulse (10.6mA for 12.72us) = 134.8uC
BUT in the 'WITH FEEDBACK' case, 24.4 uC are ALSO transferred BACK to the supply to be re-used;
whereas in the 'WITHOUT FEEDBACK' case, NO charge is recycled
the result is that the runtime of the 'WITH FEEDBACK' lasts around 20-30 % longer, with the same average power delivered by the supply to the circuit throughout - ie. some of the total energy converted is recycled to perform approx 20-30% more work
it appears that this 'WiThFeedback' circuit is able to gather energy which would otherwise have been dissipated and lost, and re-use it to do extra work
energy is conserved - work is not!
np
itsu
NP,
nice analysis, i like it.
Quoteit appears that this 'WiThFeedback' circuit is able to gather energy which would otherwise have been dissipated and lost, and re-use it to do extra work
But, to my understanding, considering your: "gathered energy which would otherwise have been dissipated and lost"  this dissipated energy also did work to get dissipated.
Not sure yet in which form (heat, light, radiation), but it was doing work then.
So would you not say that you utilized this "dissipated and lost energy" by using feedback and so improving on the overall efficiency (input versus work done) of the circuit?
Itsu
