To be deleted
Started by nul-points, February 02, 2016, 07:23:16 AM
synchro1
Dragone and Zaev.
A few contributors have offered theories about the magnet core coil gain; mentioning field compression etc. These guys are reinventing the wheel.
Tinman and Itzu need to take caliometric readings of the coil's core magnet. They will find their magnets are cooling.
The PM field is not compressed it is annihilated by a dealignment of polarized electrons caused by the electrical pulse.
The Neo-magnet material has to work on the quantum plane to reorganize its alignment and consumes heat in the process. Electricity is generated by the work.
These are the theories of Dr. Leon Dragone and Nicoli Zaev.
synchro1
When the current is interrupted, the magnetic field is removed from the Neo magnet, an (MCE) material. This causes the electron spins to become random and the material cools.
"All magnetic materials exhibit MCE, although the intensity of this effect depends on the properties of each material. Generally, for a simple ferromagnetic material near its Curie temperature, when a magnetic field is applied, the spins tend to align parallel to the magnetic field, which lowers the magnetic entropy. To compensate for the loss in the magnetic entropy in an adiabatic (isentropic) process, the temperature of the material increases. When the magnetic field is removed, the spins tend to become random which increases the magnetic entropy and the material cools".
That's all they tell us in refrigeration science. The problem for them is that when the magnetic caloric material begins to work to re-polarize it's domains, it generates electrical power. This is an unwanted byproduct they simply run into an Earth ground. Tinman is running a D.C. motor with MCE waste current.
nul-points
Quote from: synchro1 on January 12, 2019, 02:05:21 PM
Dragone and Zaev.
would have loved to see the expressions on Leon's staff-colleagues' faces when he handed them his lovingly hand-typed theory paper for discussion
only saw Zaev's 'h' type current waveform once, in one of my pulsed motor experiments - real - but elusive!
ciao
synchro1
Tinman or Itzu need to measure the temperature of their Neo magnet core to see if it's dropping while under operation. This will prove wether we're witnessing an (MCE) or not.
synchro1
2SGen Episode 6: The 2SGen principle: The energy from the core magnetization/demagnetization process
In the scope pictures below:
the yellow curve is the pulse sent by the controller to build up the magnetic field of the core (magnetization phase),
the blue curve is the pulse measured across the output coil connected to a lamp as a load.
                               (http://jlnlabs.online.fr/2SGen/images/2sg1b.jpg)
Look at the blue curve, the first part (negative curve) is the magnetization phase of the core (building up of the magnetic energy), you may notice some Barkhausen effect bumps.
The second part (positive curve) is the demagnetization phase of the core. The excess free energy is tapped during the demagnetization process and not during the magnetization process due to the blocking diode connected at the output coil. To get more free energy from the 2SGen device, the clock pulse must be as short as possible (during the magnetization process).
The process of free energy generation from magnetization/demagnetization of a ferromagnetic core has been fully explained in the Nikolay E. Zaev paper "Ferrites and Ferromagnetics Free Energy Generation" published in New Energy Technologies Issue #5 Sept-Oct 2002.
