Is the free energy gamechanger here ? 2000 Watts u-plug generator
Started by hartiberlin, February 04, 2016, 11:21:58 PM
Dog-One
Quote from: verpies on February 05, 2016, 04:53:41 AM
What if the Tamper Protection kicks in and and obliterates the unit ...or it explodes in your face?
We draw straws to see who is the lucky one.   ;)
I'd rather look at a patent to see how it works, but seriously, if I have to pop the top off one of them tubes after running a harsh overnight test on it first, I'd do it.  Maybe make a video of the U-Plug untubing.   ;D
I did a little poking around this evening and it smells a little fishy to me still, though I did get an email response from them--they would like to know my location so they can have a local dealer rep speak with me.   Hmmmm....
I tracked the originating IP and it came from Provo, UT.  Could Tim be visiting Sterling Allen?   One wonders...
http://www.iptrackeronline.com/index.php?ip_address=69.89.31.140
We shall see.  Probably end up in the Keshe bin, but like Chet said, no stone unturned.
pomodoro
Looks like these guys learned how to make money by watching those Aussie Russians with their flashlights.   8)
lumen
I think the logistics are off and there would be problems like heat buildup in that tube and how can it weigh only 20lbs when they use several magnets with a force of 2500lbs? That would indicate many large heavy magnets.
How it works
We developed a simplified planetary gear system with multiple shafts that have our magnets in them. Each magnet can pick up over 2500 pounds each. There are several magnets per shaft, and when they are in the proper position they begin to spin. This will cause a push pull type of effect that has  worked quite well for over 2 1/2 years. Then we surround the unit with the field coils to generate the power.
We cannot give to much more info without divulging our secrets, so we have kept this explanation as simple as it is.
The U-Plug Green system will generate between 17.25 amps and 19.25 amps. and is controlled by 2 circuit boards located at the top of the unit. We have set the unit at 2000 watts maximum for reliability.
The circuit boards control the speed, amperage, and the output wattage so that the coils are not damaged. Other safety devices inside the unit are provided in case water gets inside, and to protect it from overheating.
Maximum operating temp, Fahrenheit,  is 125 degrees and so far we have found that the unit will operate at -60 degrees with no problems.
Only 125 F? Well, that pretty much eliminates using it during a hot Texas or Australian summer, or in military operations in any of the many deserts we have invaded.
No wonder the "US Government" only ordered a couple of units. Heck, my attic gets over 125 F around 8 months out of the year. Hey, I know... you could buy two and use one to run an air conditioner to keep them both cool....
The magnets and gear train are only supposed to weigh 7 pounds. That's about 3.2 kilos for the metrically inclined. Most of the rest of the 20 pounds weight is supposed to be in the copper coiling. I wonder where they are buying their magnets....  and what material they are using for their gears?
Provo Utah? That's the last known address of Joe Firmage's operation, there at the airport.
