Is the free energy gamechanger here ? 2000 Watts u-plug generator
Started by hartiberlin, February 04, 2016, 11:21:58 PM
sm0ky2
I shall further compound this by stating that when the magnets are in repulsion, and a moving plate of copper passes quickly between them, they will attract to the copper, within a range of forces, and when the copper leaves their near-field, the magnets will again repel each other.
The potential energy between the magnets after the copper leaves the field is equal to the energy required to force the copper plate between the magnets at said velocity. The eddy currents try to prevent the motion of the copper, while the motion of the copper creates the eddy currents.
It is a directly proportional relationship. And a completely conservative field-gradient, much like gravity.
This is because non-magnetic conductor, generates a time-variant field effect.
What we otherwise call "electromagnetic induction".
Electro - which comes from the greek 'electron, which literally meant Amber, in motion.
    i.e. - a time variant occurrence.
passing an attracting permanent magnet through the space instead of a copper plate, results in a similar reaction, without the time dependency.
In either case, the resistive forces over distance, are equivalent to the potential of the magnetic field gradient, through which the repelling magnets passed.
Poit
Just the fact that they are asking for money sounds the alarm bells to me.
It would be like someone inventing a way to turn any metal into gold (alchemy) and then saying they are broke and need money, its just stupid... if you have the goose that lays golden eggs... why ask someone else for gold?
forest
Quote from: Poit on February 07, 2016, 05:18:53 AM
It's not a good analogy. Better is the buried treasure. You need money to dig it up.
lumen
Quote from: sm0ky2 on February 07, 2016, 04:01:27 AM
Sm0ky2
Did you find this by your own testing?
In the next drawing it would seem that all drag could be removed except for a small amount in the spinning copper tube and any drag should be equivalent to a proportional force in movement around the stationary center magnet.
Without the copper tube rotating the outer magnet and tube could simply rotate around the center magnet without any drag, so any drag on the rotating tube should represent a shifting of field along the compression line and cause some motive force.
sm0ky2
My view of this particular set-up, I would expect a force between the inner surface area of the copper tube and the center magnet, during rotation. counter to the direction of motion.
(I am assuming that the center magnet is not rotating in this setup)
given the asymmetrical distances between the two magnets with respect to the copper plate.
I doubt that's whats in the U-plug's white casing.
