Is the free energy gamechanger here ? 2000 Watts u-plug generator
Started by hartiberlin, February 04, 2016, 11:21:58 PM
lumen
I agree that it's likely not what's going on in the U-Plug device if it were real, though it does seem to fit the wording in their description.
Through many years of testing magnetic interactions I believe it to be impossible to build a magnetic motor, but still every time someone makes a claim of such a device I always wonder what I may have missed.
tinman
Well,a lot of guessing going on here ;)
We see in one of the demo video's that they are running a small gasless mig welder from there 2kW unit,and can continue to do so for some period of time. So where are the cooling vent's?. I mean to say,it's all in a PVC tube,and being white PVC would indicate that it is standard grade PVC use to transfer water. This PVC dose not like heat that much,and i would think that the unit would get hot when delivering enough power to run that welder in a very short time.
They say there is no inverter in the unit,so how is the frequency regulated if the power being developed by the unit comes from some sort of magnet generator?--some kind of converter maybe?
There is also the magnets they claim to be using. As some have pointed out already-they would have to be quite large and expensive. Seems the planetary gears are made from some sort of plastic/teflon material--must be some fantastic stuff to cope with the load's/forces those magnets would place on those gears and carrier--if we are to believe the pull forces from those magnets are what they claim them to be.
Added
So each magnet has a pull force of 2500LB's = 1.133 ton
Who here could place two of these magnets close to each other,and hold them into position with plastic gears and hub's,that fit into a 6 inch PVC tube ? :D
I think this one needs to be filed in the bin.
Brad
tinman
Im thinking more-->
https://www.youtube.com/watch?v=GPJao1xLe7w
Then just recharge with a solar panel,and you have clean green free energy ;)
Brad
guest1289
Quote from: lumen on February 07, 2016, 05:52:22 PM
    The following post,  shows my three best ideas for a magnet-motor
    http://overunity.com/15774/permanent-magnet-motor/msg473357/#msg473357
     First, using a half-hollow-dome-magnet,  you should achieve a magnet with a  flat magnetic-field on the surface of the hollow,  and if you use a half-hollow-oval-magnet,  then the field is sunken into the hollow section.
     I suggested that as a way to base a  magnet-motor  on the design of the   'Wheels-with-scoops'  that are propelled by water in  hydro-electric-power-plants .
     But,  on that post,  I also updated my  magnet-motor-1,  and  magnet-motor-2,  two very different ideas,  they are detailed in earlier posts in that thread .  I think these are my best  magnet-motor  ideas .
    http://overunity.com/15774/permanent-magnet-motor/msg459551/#msg459551
       In the post above,  I posted two possible ideas for  creating  a proper  Donut-Magnet  with the  magnetic-field  rotating around the circle of the  toroid.
       (  Those diagrams,  and the description I typed,  were not good quality )
       The  Donut-Magnet  being created,  could be either  physically-supported in both ideas,  or it could possibly be levitated,  either by the magnets  turning it into  a proper  Donut-Magnet,  or levitated by other magets .
        I assume people would be interested  in  having  a proper  Donut-Magnet  with the  magnetic-field  rotating around the circle of the  toroid,  in order  to have a  monopole-magnet,  which no one has ever achieved .
          I wonder if there's any possiblity possibly that  https://en.wikipedia.org/wiki/Persistent_current  could exist in a  proper  Donut-Magnet  even if it is not a  superconductor .
Dog-One
Quote from: tinman on February 07, 2016, 06:50:42 PM
See what I mean by not adding up?
It would take considerable aerospace technology to pull this off, not that it couldn't be done with a multi-million dollar budget; unlimited equipment and talent behind it.  But seriously, who would go to all that trouble to sell a sub $2k unit to the public.
Probably best to let this soak and maybe someone will come up with a half-baked mechanism that self runs, based on some of the clues.  The killer would likely be the tolerances needed to achieve motion, something out of reach for most garage experimenters.
I'm still due an email back from Tim after he asked for my location.  Said he would connect me with a local distributor.  Not holding my breath.
