Free Energy Party Green Machine - 3rd Party verified Overunity Electrolyzer
Started by hartiberlin, February 07, 2016, 09:40:59 PM
zorrotechnology
The test results showed breaking the barrier of the famous 1.23 volts. We will show the unit running on on a 3.7 volt lithium ion because it is handy but give a moment and next he will show a 1.22 Volt that breaks history or scientific standard.
But the inventor doesnt like to think of it that way,he is very humble.
He says he is just going to show something that is not supposed to happen. And he believes that God has shown the Free Energy Party as the way to move this into the open.
He is humble and genuinely good. He just wants to do good in this world.
He will show it ringing it and pulsing it with on the board voltmeters in and out
he will show the change of voltage and use outside gauge as well as the board to show that it is accurate. This electrolyzer atypically shows endothermic reaction not exothermic, it gets cooler not hotter...other electrolyzers get hotter and hotter..it will start a war of words and a debate.... I will be bombarded, but I am used to that.
zorrotechnology
THE GREEN MACHINE
Anything under 2.4 watt hours per liter is over-united according to David Wenbert using traditional water electrolysis and applying Faraday conversion ratios ..... 500 watts for 1 minute makes 20 liters. Per liter, that's 25 watt minutes. Next divide by 60 minutes in a hour, get 0.416 watt hours per liter. If you did the math, ie 2.4 divided by 0.416, there is room to prove overunity with overground demonstrations even with a Chinese gen set running on the order of 0.25% efficiency. But for home installations we will use the 90% efficient PEM fuel cells to power the home. If I have used any incorrect terms try to help rather than attack since the Independent lab says this is a world breakthrough lets work together without animosity.
ZeroFossilFuel
I learned something new as well! If true, then this is indeed OU. However, considering the electrical configuration I am still hard pressed to believe what is being produced is 100% HHO. It is far more likely that there is boiling taking place creating large amounts of water vapor that is being lumped in with the total output. Not that it too does not benefit the typical ICE, because it does. Just saying.
My public PGP key. Please help support my work. Donate by PayPal
zorrotechnology
your note regarding boiling is logically appreciable but apparently not the case sir,  this is reportedly an endothermic reaction it would appear not exothermic so that the process gets cooler than hotter. We have more Independent Test Lap documentations to post ...
hartiberlin
Dave from the FreeEnergyParty.org told us:
It is a world breakthrough efficiency in turning water to hydrogen.
It works via special resonance and pulses and and harmonics and special materials and special design,
breaks the 1.23 Volt  standard for hydrogen production, because it can get it done at lower voltage.
It makes enough to run a motor , there are two larger units volumetrically a hundred amp alternator is
over a thousand watts which makes 40 liters per min of hho mixed in with  air to
mellow it a hair and turns itself off and on ....yup
it is so incredible that a multi million dollar independent lab went over this running it for two days......
and it breaks a couple of records in history it appears
