Water activated light...no more batteries
Started by markdansie, February 11, 2016, 08:17:46 AM
markdansie
Hi TK
please email me your address again I will send you one. The new one is maintenance free, the waste is contained in the cell. We are also doing a fully bio degradable one made from bmboo.
I sent Stefan one some time agao
conradelektro
Quote from: markdansie on March 22, 2018, 05:30:31 AM
Hi TK
@makdansie, TK, Stefan:
May be markdansie can answer my question, or Stefan and TK will have some experience with the water activated battery.
I understand that the water activated battery can be stored for many years as long as it is not activated (stays dry).
But what happens once it is dipped in salt water? A slightly acidic solution will be created in the battery which allows a corrosion process causing electrons to flow between anode and cathode.
Electrons only flow if the light is turned on. So one could let the battery dry out without using it up. And later one ads water again to create the acidic solution again.
I imagine that letting the battery dry out causes chemical reactions which are not reversible and therefore constitutes some "loss". The "loss" will probably be a shorter electricity production than in the case of a one time cycle.
Case 1: adding water and turning the light on and letting it shine till the battery is used up will give you light for instance 100 hours.
Case 2: adding water, turning the light on for some time, then letting the battery dry out, adding water again, and letting the light shine till the battery is used up, will give you in total light for a shorter time than in case 1.
Now the question: how much are the "losses" if one lets the battery dry out and adds water again months or years later?
This is not a criticism, I just want to know how the battery reacts to multiple dry outs.
Greetings, Conrad
profitis
"Now the question: how much are the "losses" if one lets the battery dry out and adds water
again months or years later?"
chemicaly speaking,there'l b a major buildup of scum over time.resistance increases
LeoMax000
Quote from: hartiberlin on February 13, 2016, 09:56:54 PM
Many thanks to Mark Dansie by bringing this finally to the market.
I guess their new Website URL had not been posted here,
so here it is:
http://www.hydra-light.com/
I think this is also an metal-air battery so the graphite plates have to be able to breath air, that is Oxygen...
as Oxygen is needed to be converted at the graphite electrode to go into ions to decompose and magnesium alloy
and to produce current...
So if other persons try to replicate this, make sure your graphite plates are not always under
water or fully inside the electrolyte bath, cause otherwise they can not "breath" air and thus they only can convert the air, that was stored in the graphite matrix, before they were put into the saltwater....
I also always wondered myself earlier, why my saltwater cells became more and more weaker, when I realized
that the graphite electrodes can not breath any air anymore, when they are almpst completely inside the saltwater...
So the best thing would be to put these graphite plates on one side as the wall of the container and with the other side in contact with the electrolyte,
so on the one side they can fully "breath" the air and at the other side are fully immersed into the saltwater electrolyte...
It seems they have exactly done this as you can see here:
http://www.hydra-light.com/#!technology/c24vq
Especially seen in this great picture:
https://static.wixstatic.com/media/4b4cbd_bc14c62da3a5423d9f92d4e3f7e83c26.png
The graphite plate seems to breat air from the other side not beeing in the saltwarer electrolyte...
Well Done Mark Dansie and Team !
Regards, Stefan
jimbo
I never cared for consumption batteries with metal that require you to reconstitute them with more electric energy .if you use zinc and carbon air batteries you'll need to move air thought the carbon to jump the power .but the zinc oxide can be reconstituted by heating to red hot like in a solar Furness or camp fire with air pre heaters .if mixed with carbon it turns to zinc vapor that's why the high temp must reach vapor point to work .then the vapor collects on lead sheets in side of the cooling area and comes off easy .then refuel your cell.using the sun or just fire wood seems better than hoping the powers still on .and you can scale it up and store it . try Penny's  they melt in a stove flame .
